Results 1 to 7 of 7
Thread: Some problems running Super_Pi
    Jan 2005
    Argentina
    Question Some problems running Super_Pi
    Hi, I have same problems running Super_Pi at 270x10 with my setup. Before running Super_Pi at 270x10, I used Memtest to test the timmings and run 50+ passes without any errors. I used 1.525v + 110%=1.6775v for the CPU, 1.6 and 1.7v for the Chipset, and couldn' t even finish 4 loops of Super_P1 1M test.
    thanks in advance,
    Matias.
    AMD Athlon64 3000+ LBBLE0522CPMW Venice
    XP-120 W/panaflo 120mm
    DFI NF4 Ultra-D 623/2 Bios
    2x512 OCZ Platinum Rev2
    ATI X800GTO²@X850XT PE
    OCZ PowerStream 520ADJ
    DVD-RW Pioneer 109
    Maxtor 120GB SATA
    WD Caviar SE16 250GB SATAII
    Jun 2004
    CPU oc 2 high, lower the CPU frequency.
    E5200
    Asus P5Q-VM
    A-DATA 2x2GB
    Zotac 8800GT
    500W Seasonic
    Quote Originally Posted by trakslacker
    har har! Geforce strikes again with one of his "theories"
    Jan 2005
    Argentina
    Quote Originally Posted by $0m#0n#
    Yes, it could be a possible solution, I have used Super_Pi at 265x10 with no problem, getting 33s, but I wanted to get a better score.
    Windows run flawlessly at 270x10 and memtest passed 50+ times without any error, so I guess it was fine, but Super_pi failed at loop4.
    Thanks.
    DVD-RW Pioneer 109
    Maxtor 120GB SATA
    The Blue Dolphin
    Nov 2004
    The Netherlands
    Is it Prime-stable?, if it is, it should be superpi-stable.
    Jan 2005
    Argentina
    No, I used memtest only, because my cpu reports very high temps, and I know this is not true because the heatsink is not even warm and running Prime95 reaches peaks of 65°c and the pc shuts down
    I have tried all the bios available for my mobo, but I don't have any luck with this.
    DVD-RW Pioneer 109
    Maxtor 120GB SATA
    Xtreme Mentor
    May 2004
    the cold place Temp: 5C
    how tightly do you have the HS screwed on?
    For those of you about to post:
    Jan 2005
    Argentina
    It's an XP-120 craig588. It is attached by clips to the retention frame that came with the XP-120.
    DVD-RW Pioneer 109
    Maxtor 120GB SATA
