i'll ask for it.
is it the same chilly1 is using?
i'll ask for it.
Back in the phase change world
i changed the holddown a bit to make it look better
Originally Posted by chillingdude
no that is PVC, but is good also PVC
another dry ice run is almost comming.
5may is the day.
i am posting on some forums localy to ask if someone is intrested.
i am going to provide 12 containers if everything goes well
6 cpu and 6 gfx
there is going to be enough DY, somewhere about 30-40 kg
youre going to see some movement on the orb
working on an new gfx container.
How much do you ask for cpu containers
prolly around 45€
i don't know the exact prize because i receive the tube tomorrow.
i have calculate how mutch holddown and rings i can cut out of the plexi.
and prize of insulation etc,
i'll post it when i got more info
still need to do the other 5 piece's
done
don't forget to watch to the livestream thats going to be there @ 5 april
http://jortcollijn.ww.com/
Lol nice, I will watch it (how late does it begin)Originally Posted by Jort
it starts around 1pm and finished @ very late.
time is GMT 3+
I hope that you can break the record, Good LuckOriginally Posted by Jort
tnx, w'll do our best
VERY nicely done I just got 50cm of 50mm tubing (2 inch) and i'm now looking around for a place that can sell me some 3 inch tubing.
I'm going to put the 3 inch stuff over the 2 inch, so it's double walled, and i'm going to put a seal on the top, put a valve on the outside piece of tubing, and solder it all together. Will take a while to do since I don't think i'm gonna be able to find the 3 inch tubing for cheap in a hurry (everyone wants to sell me nice long pieces and doesn't want to cut what they've got) but there will hopefully be a video when i've finished it all.
Again, nicely done You said the 5th of may then mentioned the 5th of april, but which one is it?
---dens
Current Testing Setup: || deNs Custom Single Stage Unit | E2160 @ 3.7GHz 1.58v | Kingston ValueRAM 2GB PC6400 @ 4-5-4-12 1000MHz 2.2v | Gigabyte P35-DS3R rev2.1 w/ vDroop Mod ||
5 April
Jort do you already now what you are going to ask for the containers.
Haha damn you! I want that copper! What's the diameter of that stuff anyway?
---dens
hey are you also going to make a movie of it because i dont think ill be awake as i am gmt -5hours
D2OL will be on and off this summer due to heat
man, i thought i was wierd, and then i started hanging out here at Xtreme Systems-Disposibleteen
Rig1-Sempron2800+,ABIT NF7-S REV 2.0,Radeon9200se,No-Name350watt PSU,
Maxtor80gigs harddrive,K-Byte 256mb pc2100 & Ultra 256 pc2100 Ram, No-Name CD-Rw Drive
2" 1/8 is the exact size.
nope i don't paid the copper tube yet so i don't know the priz.
btw i made 2 cpu containers allready
btw don't worry about the tube thats wider then the baseplate.
it was on purpose, the baseplate needed to be that small because of the compability of LGA and AMD XP
Looks really nice Jort - top nice tubeing.
Could you send me a 60cm hehe?.. i cant seem to get a hold of it here in denmark.
PM, me if you dont mind.
Jacob Hansen
keep the containers comming
jorts little army of cooling down white dry ice and ln2
