Good job so far. Go for the highest 2001 score on the orb. I think you'll break at least 40,000+ with an FX-55 under DI. Anyways, Good Luck, and dont forget to post results.
no i wont
yes there is a chance we hit some records
fx does 3.3 under vapo ls
and his 3500+ does 2.75 little above stock vcore and my 3000+ does that too so.(all stock cooling)
x800pro flashed to xt(voltmodded) does 681/644 wccooled
Back in the phase change world
benchingday was a succes and a non succes.
first, we got it all running for 4 hours straigh benching.
we managed to get 3.5 ghz stable on a fx 55
because my procc fell from 0.5m above groundlevel to 0m some pins where damaged.(concrete floor)
tried to get them all straight but 2 were hit too hard, so broke off.
going to test tomorrow if it maybe would work because i heared that some pins are there for no use.
x800 container was not optimal, his ass was to big so proper installation and insulation was not easy.
we got it running and core was -33 but we couldn't get it stable @ every setting and voltage.
going to update tomorrow when i got some sleep because 4-5 h of sitting outside and tonight(this morning ) 6h of sleep is devestating.
pics will come, when i can release them
don't ask why or... just wait and see
ps: if you put dry ice in a bottle and close it it saids BOOOOOOM.
i'll post the movie with the pics
for info we got 15 kg of dry ice and after 5h straight with the last hour 2 containers we got 9+ kg spareOriginally Posted by Da_Boka from Madshrmps
Good stuff dude Everyone's gotta learn the first time, and it seems like you had a long and informative benching session 3.5ghz stable FX-55 is very very nice
Good luck on getting the problems sorted out and going higher!
yeah its going to be next vacation.
in about 6 weeks so by then every insulation and mounting problem will be solved.
and where going to run some ln2 maybe
where hunting WR.
to bad the container didnt go so wel on the X800.
what CPU fell? the FX-55 or your AMD64
nice project...keep it up !!!
SOON) Dual Core Opteron 165 - Shuttle SN25P - 2*512MB TCCD - 36GB+2*250GB - X800GTO²
Dual AMD 1800+ MP - 3*200GB + 3*300GB RAID5 - LSI MegaRAID 150.6
Acer TM 4000 LMi - Hyundai ImageQuest Q17
fx is an amd 64 too.
its my procc that fell off.
look @ sig
have GOOOOOD news.
mobo was not dead and cpu neather.
so i've got 2 msi k8n neo2
an 3000+ and a new 3200+
3000+ with 2 missing legs still clockes excelent
3200+ is not that good 2.6 max on air
but almost no hardware-loss after all
mx420 is doing nothing atm, some further checking w'll happen
Always glad to hear there were no casualties
nice work...still missing pics
hey you are a lucky guy, aren't ya? many of my hardware died during the last 2 months because of no reason...and a 3500+ was killed by our "post"
nice to hear that hardware isn't this sensible always
pics are comming tomorrow.
talking about luck with hardware
i have burned my A64 3200+ clawhammer last week btw
that suckes.
how did you do that?
don't know....i have shut off pc and it never rebooted...
Originally Posted by Malachia
can you see the light? is it shining too bright? can you see the light at the end of the tunnel, i know i do, i know its true.
now i am playing with 775 E0, i am going to build a new DY container and a phase change for vga...754 was quite old...
@blinky
i still have friends with A64, don't think you have win the war
were still running fine
http://users.telenet.be/jortcollijn/...king/owned.JPG
http://users.telenet.be/jortcollijn/...ng/2841mhz.JPG
running beta watercooling (chipset and cpu)
nice work, now let's rock
i also will present my new dry ice container until the end of next week
Hi,
Your container is toooo big, you planned to make it run a long, ha?
My DI container was a cylinder at 42 mm Diameter and 2 mm wall thickness, and 400 mm height, holds a burning 3.6 prescott around 1/2 hours.
Reflect this capacity to yours, I hope that it will go for 1,5-2 hours without any feeding.
anyone?Originally Posted by meke
if you read the topic you will see that my container is EXACT 400mm
and its 50mm diameter and thikness is about 2mm too
so your saying your container is too big too
1st=> i think no container is too big
the bigger the container the bigger the pressure on the bottem and better results as result
2nd => DI run is already done, posted some posts above.
Pics will be here @ time.
yes you are right, then only the diameter is %25 bigger, thats ok.Originally Posted by chillingdude
So you reach max 1 hour for fx55?
we didn't mesure it. because we didn't have an temp probe for such temps we kept
the container always almost full of dry ice.
comment on the way but going to sleep now.
