What I'm saying is I dont think the temps will increase from a surface lapped with 600grit sandpaper and 1000grit sandpaper.
well, the flatter the surface, the better the contact will be, so the better the thermal transfer will be. Its just that difference would probably be neglible at best.
Originally Posted by chillingdude
agree 100%, also i like mirror-lapped coolings!
Originally Posted by moddolicous
he replyed that you r in right, but 1000 is a lot more beatiful, is only for good looking 1000!
yep youre right about that.
Back in the phase change world
i've got a question for the one who knowes the answer
can plexi hold if the temps around it are -195(ln2 temp)
my plan was to make a container thats compatible with P4 s487, A64, P4 lga775
and make socket kits for each on in plexi
policarbonato (don't know englidh name ) or PVC
like chilly1?
where could i buy it?
i live in belgium remember, in the usa you can buy everything @ local hardware shop
Malachia lives in Italy. I think what he means by policarbonato is polycarbonate, or plexi glas. You can try that.
policarbonato is like plexy, but have more torsion resistence....
i buy it in a place that sold only plastic materials, like plexy pvc ecc ecc
i whant to see insulation plz!!!!
today i made myself a gfx container, its perpose is to clock an x800 as high as possible
i'll show you some pics.
2nd
3th
4th
i'll take some pics of insulation asap(fixed)
thx
p.s good job
thank you
pics are there
Well done!
54mm pipe? Looks almost the same as my gpu containers
Did you brazed the screws too?
no i didn't braze them, they are melted too because all the silfos
55mm pipe
dry ice is ordered, 15 kg on the way.
going to have a very nice day tomorrow
lol 15kg is A LOT.
looking forawrd to the results
yeah when i got him on the phone i asked what can i think about if we order 10kg
he said like a square of 30cm
oke its big but hey i can take some with me and test @ my place with an mx420 that fits the container nicely.
en we have some spare left for fun
next time we would now exacly how mutch we need to fill 1 container.
ps: we are going to test, 3000+, fx55 and 2 times x800 so 4 refills.
i'll calculate whats the content of 1 container
1 container is 784 cm³
and 10 kg was square 30cm
if my calculations are right 27000 cm³
and 15 kg is about 40500³
i called and he said if you take 10kg=> have to pay extra for transportation.
15kg is tranportation free
and 20% gets lost after 24H
so i think we have enough then
and again an update of some stuff.
- pics of the board to mount the mobo on
- pics of insulation
- pics of bracket to hold the graficscard, or prevent braking of
2nd
later this day i'll post some pics of total insulation of the containers
