hi guys,
i wondered, what benchmarks can i run on a mac? are there any special versions of 3dmark / pcmark or any other popular benchmarks for the mac os x ?
hi guys,
you can try xbench, but you wont be able to compare it to a regular PC.
xbench is really the mac benching standard now. I don't think there is anything else, besides doing a code compile test or SPEC or something.
oh... i guess the field of benchmarks for macs is really neglected... bummer
are macs over clockable??
on the CPU there is usually a resistor that controls what speed it runs at.
http://www.xtremesystems.org/forums/...ad.php?t=48429
here's my thread. It worked, but I had to add a fan so it wouldn't overheat. Not really worth it, but fun to try.
yea i havent found macs very exciting, sure there are less viruses aimed at getting into the mac operating systems but this about their only advantage imo.
they have some, but yeah software support isn't that big. Kinda sad...could be a very nice platform
jjcom
yea, maybe, ill stick with a good ole, overclockable pc though
are there any frame rate appz like fraps for mac?
There might be a way so that when you load a game on a mac that it shows the FPS, but I'm not sure about that. I have an older mac so I cant test it, but I know someone who can
yesOriginally Posted by Saliman
can you please tell me what are their names?Originally Posted by boshi
sup guys
i found a benchmark called CineBench 2003 thats supposed to be for mac & pc both.
it appears to be pretty popular, judging by its appearance on the most popular downloads list of guru3d.
Hmm.
I love macs. Everything about them. Stylish, powerfull, reliable. Though also expensive and dull - the high point of "tweaking" it is installing Mac OS...
But as a work laptop nothing comes close to them. Thier displays are also magnificent, though I would take my DFI setup over a G5 any time, because I can make this computer crash without trying too hard, but mainly, play around with it so long untill you get the most performance out of it
In short, both AMD and NVIDIA discovered that their next-generation graphics cards are superior to each others' last-generation graphics cards.
