A few days ago, I downloaded Aston shell, which is a Windows shell replacement. Now my Windows load faster, and moreover, I get a slight performance increase. Try it here:
http://www.astonshell.com/
"Strive for perfection in everything you do. Take the best that exists and make it better. When it does not exist, design it." - Sir Henry Royce
Any change in benches, or just regular use performance increase? (I usually kill explorer to bench anyway, so I'm assuming no.)
tested it some time ago. isn't faster if you normaly kill explorer.Originally Posted by wr0x2
E2160 @ 360x9, max 390x9 watercooled
GA-P35-DS3
Cellshock D9GMH @ 545mhz cl5-5-5-5-15
Palit 7300gt 500/1000 @ 780/1600 watercooled
It gives me 1 second less in Super PI (as if I killed explorer), but I think its only something like the 0.2s I needed, not a whole second.
Let's give it a try...![]()
What version of win did you all install on....aslo, any unstability so far?
I have Xp Pro with SP2 and i didn't get any unstability at all.Originally Posted by tinker77
It's very easy to install and to change the skins but I didn't become accustomed with the changes at all.
Try it..![]()
