+ Reply to Thread
Results 1 to 3 of 3
Thread: Question the NEO2,Corecenter and phasechange cooling
    Jan 2005
    St.Louis, MO USA
    0
    Question Question the NEO2,Corecenter and phasechange cooling
    Forgive me if this should have been under Phasechange cooling, I wasn't to sure which place would be better.
    Anyways, I was wondering if NEO2 owners that are using phase change cooling could tell me what temps corecenter reports under full load?
    I know the readings can't be trusted but do any of you see a 20+C temp increase from idel to full load?
    Xtreme Member AKRedneck's Avatar
    Jun 2002
    Eagle River, AK
    0
    40°C all the time with my Mach1...full load, idle, high volts, low volts. Well maybe I see 39° once in a blue moon but otherwise it's frozen at 40°. It's meaningless. From idle to full load I see about 6-7° difference on the Mach1 evaporator readout, but that may not be real accurate either..
    DFI NF4-SLI Expert
    3700+ CABGE 0515SPMW @3.2ghz (291x11) 24/7
    Prometeia Chilled!
    7800GTX Watercooled
    TwinX1024 XMS4400C25
    WD 74gb Raptor
    Dell 2405FPW
    www.LATENIGHTBOYS.com
    Jan 2005
    St.Louis, MO USA
    0
    I knew the readings were a little messed up but geez.....While I'm not using phasechange cooling, I am using a watercooler that is outside so the water is chilled nicely. I'm seeing 25-30C idel with my FX-55 at stock but as soon as I start Prime95 it shoots up for 55-64C!!
+ Reply to Thread
