amd 3500 90nm
on stock cooling/as5 with a lot of airflow, my asus probe says im at 33c idle
is this acurate? my bios says 37, and im going try ocing, so what is the average temps?
amd 3500 90nm
thnx, what voltage?
i tried it at 220 with a multi at 10 and stock voltages and it was unstable, so shoul i raise it?
That sounds more like a RAM limitation. Try to up your RAM volts to 2.8v, if that doesn't help than start loosen your RAM timings to something like:
say stock is 2-3-2, try 2-3-3
jjcom
Your bios temps will normally be higher than asus probe because of the halt command once Windows gets loaded, nothing to worry about there. My idle temps are around 34-35 this time of the year with my 3500 Winnie and depending on the load, as high as 45.
With my Asus board I need 1.45v on the cpu to run at 2500, I see you dropped the multi to 10 and upped the HTT to 220 which really isn't an overclock, it's still 2.2 gig.
i know i need it to be 240 or 230 to make it an overclock, it just that im a bit iffy with the voltages, isnt there like a chart on the forums that shows Oc/voltage/ and what not?
im going to try 230 or 225 with multi 10 and some voltage raiung, ill see how that goes.
btw, what the max voltage on a 3500 90nm week 37, and the v on corsair xms at 2-2-2-5?
1.6v shouldn't be bad for the Vcore, the RAM...I'm going to assume that its TCCD so 2.85v.
So yeah try out 225x10 with 1.45Vcore and 2.8v on the RAM with 2-3-2-x
jjcom
What jjcom said should work just fine for a starting point, it's usually just a tedious process to find the right combo of settings for any particular board, cpu, and ram. There really isn't any "chart" per say for voltages, just too many varied parts for something like that, just good old fashioned patience and trial and error. Oh yeah, and a lot of reboots, hehe.
yeah, just a staring point after that you need to start pushing the FSB more. O'yeah you need to drop your HT multi down to something like 3x. Lots of reboots...and don't worry you'll find quirks...on my AN7 you can't save BIOS settings from the main BIOS screen...proubly some BIOS fix for it, but I'm too lazy currently to flash. Actually worried I'll cause a problem.
jjcom
so 1.45 on the vcore, should that get me up to 240 or 250, or will i have to go higher? i just got the chip and i dont want it to fry on me. ill just wait till i get my xp120
might work. You'll just have to see
jjcom
ok, i got to 230x10 with 1.425 and i did nothing to the ram. temps are the same, it barely goes up 3c after super pi, 1m. is that normal?
btw, my ram is the corsair xms, how much voltage can that take??
yeah, try out this:
http://www.xtremesystems.org/forums/...227#post672227
That thing will cause a nice heat increase.
As for RAM, pretty much any RAM is warentied up to 2.8v as far as I know. So 2.8v is fine, some RAM might have a higher warenty such as OCZ VX but I don't know for sure about your RAM. After you increase volts beyond 2.8v you need to run a fan on your RAM so they stay cool.
jjcom
ok, vcore is still 1.425 and the cpus at 240x10, no rise in temps
ill run prime 95 soon, seems stable, max ill go is 260, would i need a boost in vcore for that?
ok, orime 95 got it to 41-42c with torture test. im moving on
ok, i ran super pi at 32m, and i get the error; not convergetn sqr05, what does that mean?
up the vcore to 1.52 @2.5 for my 0449 vpmw.
Only up to 1.5v then super pi 32M stable else I m running 1.45 too..
Idle:32 n prime load:40
yeah, at 240+ my system is unstable, up the vcore?
ok will try that soon, btw, what is the max temps and voltage for amd chips 90nm?
max volts...I would say something like 1.6v. Temps...52degree load temp max is my opition for any chip (other than Prescott)
jjcom
stable at 1.475 at 250x10, whats the best way to see if it is stable? superpi 32m?
ran 8m cals, highest temp is 42, no problems, will go for 260 tommorrow
Prime95 is good, SuperPi32M, 3Dmark2001 through 2005, and this S&M thing...search the forum for it
jjcom
