+ Reply to Thread
Results 1 to 10 of 10
Thread: What memory for DDR600 (1:1) on 865/875
    Feb 2004
    Denmark
    0
    Hey out there...
    I got my hands on a good old 2.4C wich has the ability to run the magic 300MHz FSB, but I'm lost when it comes to memory - I'm not up-to-date with what's hot so I'll need some advice to get this CPU keep playing with the big boys.
    My target is to run the FSB and memory synchronous all the way up to 300MHz FSB, but what memory will be able to do that? I made some research, but it's hard to say wich will do it because all the memory wich is potential for the task is only tested in Athlon64 based systems in wich many run DDR600+ CAS2,5, but on a Intel platform it's another story. DDR600 CAS3-4-4-8 seems to be the target. DDR480 (5:4) CAS2-2-2-5 could be an alternative, but if the DDR600 is within reach it's my target.
    The Adata and Gskill PC4800 is rated CAS3-4-4-8, but still... can they do that on a Intel platform (865/875). What with Gskill PC4400LE - are they to be considered?
    EDIT: "Recommend" memory wich is available in 2x512MB kits
    Xtreme Member WeldZilla's Avatar
    Dec 2004
    0
    Hmmm?
    If you find some that will run that high let me know!! I rhave to run my 2.4C on the 5:4 divider but, I still get some pretty outrageous Sandra mem scores!!
    So I am not complaining. but 1:1 would be frakin great. I would need it to run at at least 618DDR though.
    I love my little 2.4C. It has been pretty much replaced by my 3.0C but, I will always keep it near me.
    WZ
    Feb 2004
    Denmark
    0
    In a test of A-data PC4800 they reach DDR596 CAS3-4-4-8 on a IC7 MAX3 + 2,4C, but I most admit I doubt it's stable. The test is danish so I don't think you will understand it
    Sandra: http://download.tweakup.dk/images/ar...500/sismem.jpg
    PCmark2002: http://download.tweakup.dk/images/ar...00/pcmarks.jpg
    Xtreme Enthusiast Navig's Avatar
    Dec 2004
    Chico, CA
    0
    I've been in contact with jack at gskills, and he's tested their PC4800 on a number of mobos (including multiple P4P800s). He was clear to only expect FSB 280s on i865/i875.
    navig
    XS D2OL & RAM News jjcom's Avatar
    Aug 2004
    Somewhere, USA
    0
    yeah, agreed Navig. 280mhz is about all you can exspect which really isn't that bad. You'll still get pretty scores...maybe you could talk to someone over on the Xtreme overclocking section, maybe send 'em a PM. Someone like...Macci or The Stilt. They may be able to give you a few tips
    jjcom
    Nov 2004
    Southeast Michigan
    0
    280 1:1 is the most I can get stable out of my P4C800E-Dlx Rev2.0. Too bad cause my chip is capable of 290+ with the 14 multi.
    I have heard that OCZ PC4400EL Gold will reach 300 FSB but I am sure it is on limited motherboards. In fact I was talking with someone at OCZ and they said that is why they never released their PC4800. Cause there are few motherboards that would actually be able to take advantage of it.
    920 DO @ 4200Mhz 210X20 1.35Vcore HT on, everything except Turbo enabled!!
    MCP600--Dangerden heatercore--Apogee GTZ--Weapon heatercore back to the pump with a T-line. All fans are 120mm Sanyo Denki San ace's
    Gigabyte GA-X58A-UD3R, 6GB Corsair XMS3 1680Mhz 8-8-8-24 1.666V, QPI-3780Mhz, NB-3360Mhz
    2 Evga 460 Superclocked EE's in SLI
    BFG EX1200Watt PSU
    Windows 7 Ultimate 64bit
    5.5TB Internal HD space!!
    2 Seagate external HD's totalling 2.5TB's
    HAF 932
    2600K @ 4.5GHZ 1.280Vcore
    16GB Gskill Ripjaws 1600Mhz 8-8-8-24-2T 1.5V
    1 Evga 570 SC, 1 Evga 260 SC (Physics)
    PCP&C 750Watt Mk II PSU
    Windows 7 Pro 64bit
    2x120GB Gskill Sniper SSD RAID0
    2x1.5TB WD Black Sata III RAID0
    HAF X
    Heatware
    Feb 2004
    Denmark
    0
    hmm... seems for me to go 2x512MB BH5 - 240MHz CAS2-2-2-5 is'nt bad. At 250MHz 5:4, CAS2-2-2-5 is just as fast as 1:1, CAS3-4-4-8, but at 300MHz the diffrence increases to 60MHz between the to ratios instead of 50MHz. 1:1 would perform slightly better and maybe clearly if any modules COULD run CAS2.5.
    What about a hipro5 modded MAX3 - it reached 400MHz FSB 3:2 after he modded it. Any chance it will do it?
    Nov 2004
    France
    0
    i have test 6 dimm 512mb adata pc 4000 vitesta
    the best stick on ic7max 3 or p4c800edlx with dual and pat stop at about 285 fsb
    i don't know if it my chipset orthe dimm i boot at 2.5 .3.3.5 (bios)@285 and pass 2335 with the tweaker rock stable
    but at 290 freeze even if i put 3 4 4 8 that was very instable i don't know if that was the chipset or the dimm
    http://divinourson.free.fr/bench%20e...k/274@2335.jpg
    config 1:DFi SLI DR-3200+@2.95 or X2 4400@2.72+ 2x512 Gskill gbFFX850XTPE Saphire
    XS Intel News & D²OL enhanced enzoR's Avatar
    Nov 2003
    Netherlands
    0
    ur ram is maxed.. its only rated for 250
    Jan 2004
    West Michigan, USA
    0
    any body use them G.skills yet?? I'm being limited to 281 Bus cause my memory cant take anymore.
    I know my CPU is stable to at least 287 which is about 4.6 Ghz when I ran memory at slower speeds.
    I'm running old corsair PC4400 3,4,4,8. lookin for some memory that'll do ddr580......
    3.75 Ghz E6600 SL958 @1.4volts WC by Apogee
    Intel D975XBX2 Rev 503 BIOS 2431 1066 Strap (This Mobo SUCKS!)
    4GB Crucial Ballistix DDR1000 @ DDR834 5,5,5,15
    EVGA 8800GTX WC MCW60 (685GPU/1050Mem)
    4X74 10,000RPM WD Raptor RAID-0 (260MB/S)
    PC Power & Cooling 750 Quad
    SILVERSTONE GD01S-MXR HTPC Case
    Intel HD Audio... Saving up for i-Meridian
    Custom Designed/Built 6x500Watt + 1x1500 Watt Amplifier .005% THD+N @ 20Khz not 1Khz
    Custom Designed/Built D'Appolito Reference Speakers w/ Custom -24dB crossovers
    Custom Designed/Built 15" Digital Designs Audio 9515f tuned to 22Hz.
    52" LG DLP 52SX4D HDTV
+ Reply to Thread
