+ Reply to Thread
Results 1 to 4 of 4
Thread: Problems getting high mhz with high fsb
    Jun 2004
    Sweden
    0
    Hello
    I've been trying to overclock my 3500+ winchester but cant reach any good frequency while running high fsb.
    Im using a 3500+ (CBBFD 0437WPGW stepping). Msi neo 2 mobo with latest bios i guess, and a pair of gskill memories with tccd.
    Yesterday i tested the memories how high they were able to run. I ran some superpi and reached 300 fsb without any errors, with multiplier set to 7.5 = 2250 mhz. Then i increased the multiplier to 8x = 2400. Also ran rock stabil. So i thought what a h*ck lets continue. I set the multiplier to 8.5*300 = 2550 which resulted with bluescreen. I know from before that the cpu is stabil up to 2650 mhz (runing 10.5*250)
    Have tried many combinations to run atleast 2600 mhz
    11*236 = Stabile
    10.5*250 = Stabile
    10*260 = Not Stabile
    9.5*273 = Not Stabile
    And then to the question. What the h*ck is wrong? Why can't i for example run 260*10? My guess is that the memories are the failing link. But on the other hand, they should be able to run 275fsb with 2.5 3 3 7 timings without any problems, for now im using 3 4 4 8 timings 1:1 dividers.
    All theories are welcome.
    //Fiskaren
    My computer WAS fast
    Nov 2004
    Denmark
    0
    running 7,5x300 1:1 the real ram speed is "only" 280MHz
    But my bet is that your memcontroller is not op to both high mem and cpu
    My goal: A64 @ 10*300 - 2x512mb 1:1 2,5-3-3-8 1T
    Needed
    CPU capable of 10x300 1:1 - my week 31 winchester has a crappy memcontroller (can do 2600Mhz prime stable)
    Ram capable of 300Mhz 2,5-3-3-8 1T @ 2,8v - my OCZ EL PC3200 rev.2 not "good" enough (at least 275Mhz)
    Good mobo, this Abit AV8 is the worst i have ever owned seems to be a problem with the ram power supply
    Jun 2004
    Sweden
    0
    Quote Originally Posted by Hvidgaard
    Can you expalin that further?
    So you think that the mobo is crapping out on me?
    Nov 2004
    Denmark
    0
    Code:
    FSB	Mem	DDR	Ratio
    200	100	(200)	2:1
    200	133,33	(266)	3:2
    (200	150	(300)	4:3)
    (200	160	(320)	5:4)
    200	166,67	(333)	6:5
    200	200	(400)	1:1
    Mem=FSB*Multiplier/roundup(Multi*ratio)
    Multipliers lower than 5 is not supported, and will be treated as 5 when calculating memfrequence (Multi equals 5 if multiplier is 3-4,5).
    Meaning if you run 7,5x300 1:1 you mem=300x7,5/roundup(7,5*1:1)=280Mhz
    The memorycontroller is ondie on an A64 so i do not think that its your mobo, but your CPU that cannot handle both high mem and core. This is indeed a well known problem amongst Winchesters (including my own )
    Have you tried to raise the Vcore a bit?
    Needed
+ Reply to Thread
