My problem is mainly from the confines of my case. The only accessible fan is a single 80mm in the rear. My help needed is not so much which rad to get, but how to mount it outside the case, and most importantly, mount it cleanly and securely. I'm thinking of a large one. Fitting two or three 120mm's. On top perhaps? Is there any company that makes mounts or something? Or even props if it looks clean.
The method to get the tubing in and out isn't so much of a problem. Where the second rear fan would be, theres handy-dandy "cable passes". Go Kingwin.
