Results 1 to 7 of 7
Thread: Best DDR 2 for OC ? Corsair XMS2-5400 TwinX or Corsair XMS2-4300 TwinX Low Latency ?
    Nov 2004
    I'm thinking of buying an ASUS P5AD2-E PREMIUM with probably a 3.6 E0 (now I know it supports multiplier 14) but I don't know which of this DDR 2 is the best for stable OC:
    - CORSAIR 1GB DDR2 XMS2-5400 Pro TwinX
    or
    - CORSAIR 1GB DDR2 XMS2-4300 TwinX Low Latency
    What do you guys think ???
    Which one would be the best buy ???
    Thanks in advance for your help...
    Nov 2004
    Keller, TX
    its been proven that intels dont benifit from latency as well as amd's do so id go with the higher frequency memory.
    Oct 2004
    Boston, MA
    I would look at the OCZ DDR2, it appears to be the best available on the market right now, at PC2-4200 it has the lowest timings I've seen in DDR2 of 3-2-2-8:
    http://www.ocztechnology.com/product...2_dual_channel
    Here is a review from DriverHeaven:
    http://www.driverheaven.net/reviews/OCZ4200DDR2/
    In the review the OCZ @ 720Mhz beats the Corsair TwinX @ 730Mhz by over 300MB/s in Sandra bench because of its lower timings. And what's even more amazing is that the OCZ @ 675Mhz beat the Corsair TwinX @ 730Mhz in half of the benchmarks
    The review says, "If you have recently purchased an intel slot 775 processor and 925x motherboard and are in the market for some high performing DDR2 then look no further, this OCZ gives some seriously mind blowing performance and are the best modules ive ever tested. An unreserved gold medal award."
    File Server:
    Super Micro X8DTi
    2x E5620 2.4Ghz Westmere
    12GB DDR3 ECC Registered
    50GB OCZ Vertex 2
    RocketRaid 3520
    6x 1.5TB RAID5
    Zotac GT 220
    Zippy 600W
    3DMark05: 12308
    3DMark03: 25820
    Nov 2004
    Sydney, Australia
    Yep the OCZ DDR2 memory is far more better than any DDR2 ram out for the time being
    Nov 2004
    This OCZ DDR2 is really impressive...
    It seems that Intel also benefits, and benefits a lot, from latencies...
    I inicially thought about the Corsair modules because they seems to the good, not the best ones but good, and because I can find them at a rather good price here in Europe...
    Do you know where I can buy the OCZ at a good price in Europe ? In UK for example ?
    Nov 2004
    And now a difficult question: which of this 2 possibilities would be the best to buy ???
    1 - 3.4 with 2x512 OCZ PC2-4200 (3-2-2-8)
    or
    2 - 3.6 with 2x512 CORSAIR XMS2-5400 Pro TwinX
    I ask that because I consider the 3.6 with the OCZ memory a too expensive bundle at this time...
    Wait for your opinion guys...
    Tyler Durden
    Oct 2003
    Massachusetts, USA
    The OCZ, there is just nothing even close to touching it.
    Anandtech Review the OCZ posted today: http://www.anandtech.com/memory/showdoc.aspx?i=2306
    You can see there, with 1gb sticks, it overclocks to 821mhz stable at 2.1v (1.9v stock), while retaining the incredibily low timings of 4-2-3-8 (stock 3-2-2-8). Just phenominal memory.
