+ Reply to Thread
Results 1 to 8 of 8
Thread: Which is better?
    Jan 2004
    So. Calif.
    0
    Which is better?
    When it comes to usiing a thermal compound, which do you feel is better,
    AS5 or Ceramique ?
    Xtreme Addict Aphex_Tom_9's Avatar
    Aug 2004
    NYC
    0
    for normal use, AS5, for use with cold conditions, i think ceramique or alumina is better.
    "Monolith" - [ Xeon W3540 (4.22) - Rampage 2 Extreme - 12 GB Ripjaws 1600 - GTX 570 - 120 GB OCZ Vertex - Antec TruePower 750W - Corsair 700D - Apogee XT CPU Block - XSPC 360 Rad ]
    Old Box - [ E4600 2.4 @ 3.7ghz (11x335) - P5W-DH - 4gb Gskill @ 893mhz - Radeon 3850 ]
    Xtreme Enthusiast Malachia's Avatar
    Aug 2004
    Milan,Italy
    0
    i use down corning 340....
    Xtreme Gentoo User masterofpuppets's Avatar
    Mar 2004
    England
    0
    I use AS5 on my Mach I and Mach II fine. I did use Ceramique and Alumina a few times but it was real sticky stuff and it was a pain in the arse to remove the evaporator. Unless you are using a cascade, AS5 should be fine. If you do have a cascade, I'm afraid you just need good contact as hardly any thermal paste can work at -100C.
    XIP Dumo's Avatar
    Nov 2004
    NYC
    157
    Probly just use thermal grease that comes with the phase changer cpu kit..
    Aug 2004
    Milan,Italy
    0
    down corning 340, tested with NL2, never go hard
    Xtreme Enthusiast Unseen's Avatar
    Aug 2003
    Night shiftzzzz...
    0
    Xtreme Member SlackeR's Avatar
    Apr 2004
    Herning, Denmark
    0
    uhm its all greek to me?
    seriously, it is interesting.. if you just do a quick mount and bench for one day AS5 is better.. i would never have thought that.
+ Reply to Thread
