my idle temp on my X800pro (12 pipe) sits at 37c core / 33c ambient
under load the Core moves to a peak of 51c and ambient goes to 41c
once the load is removed the temps drop 10c quickly then tapers down
to idle temps over the next min.
Currently Iam using the Zalman GPU block, which I know isn't the best but
would it be worth investing in another GPU block and which one would
be the one of choice??
thanks for your time in this matter
