Since clear anti-freeze doesn't exist, how about blue? I know of one brand so far.. Silkolene ProCCA, but nothing locally stocks it. I was hoping for something more widely available that I could pick up here in town.
DFI LP LT X38-T2R
Intel Core 2 Quad Q9450
Thermalright Ultra-120 eXtreme
2x2GB OCZ Reaper DDR2 PC8500
eVGA 9800 GX2
WD Raptor X 150GB
PCP&P 750W Silencer
CM Stacker 830 SE
torin.. what is wrong with red zerex... it makes ur tubes look hot pink! and if its that big of a deal just get colored tubing and be done with it..
I did get colored tubing (blue), but thought red liquid running through blue tubing would end up making the tubing purple, which wasn't what I wanted. I had hoped for clear liquid so the blue tubing would just be blue, but since none exist, blue liquid inside blue tubing is the next best idea. And I don't want hot pink tubes!
DFI LP LT X38-T2R
eVGA 9800 GX2
WD Raptor X 150GB
PCP&P 750W Silencer
CM Stacker 830 SE
They most definatly make blue Anti-Freeze. Anti-Freeze typically comes in green, pink, and blue colors.
torin, here is a pic of my res with zerex in it.. u cant tell its red in tehre... u wont have a problem... just get some blue leds if its that big of a deal.
iused blue antifreeze about 1/2 year ago with didtilled water and after about two months the water became very moldy and nasty. that was when a friend suggested mouth wash and, after cleaning everything from the yucky water, i refilled it with distilledwater and blue mouthwash. and there haven't been any bacteria problems since
listerine. The OC'ers mouth wash. Now not just for your mouth!
MaxxxRacer, is your res blue acrylic?
DFI LP LT X38-T2R
eVGA 9800 GX2
WD Raptor X 150GB
PCP&P 750W Silencer
CM Stacker 830 SE
yah it is.. with blue leds in it.
VW and Audi uses blue, if there is a dealer near they will have it.
Hmm, there are two I believe. I will have to call them up. Just nothing with glycol, right?
DFI LP LT X38-T2R
eVGA 9800 GX2
WD Raptor X 150GB
PCP&P 750W Silencer
CM Stacker 830 SE
Almost all anti freeze is glycol based. The main disadvantage is slightly higher temps because of the viscosity increase, is also toxic but dont think your going to drink your coolant no matter whats in it. All anti-freeze has a higher viscosity than something like the Zerex racing coolant. But wont be major and is up to you if you want color over performance. Many things in WCn are in the 1° range and as each one is minor if a person makes too many compromises those 1° or less compromises add up to 5~6 and are a decent sized impact.
