Hey, i have a soltek SL-FRN2-L mobo, and i have made this custom water cooling setup, but my problem is, there aren't 4 mounting holes to mount the waterblock on, all i have is the stock clips on the cpu socket....
i did make a bracket, but it was flimsy, as i didn't have a square punch to make the square holes.....
The waterblock i made is the same size or just a bit smaller than a standard AMD-xp heatsink, so the only problem i am having is the clip length. I yanked a stock heatsink apart and took the clip out, but i'm 3/4" too short (1/4" plexi + 3/4" aluminum). So, as you can tell from the picture on the link, i made a custom clip, the only problem is, its really weak and flimsy.
So all i'm really looking for is some suggestions on how to get it mounted. By way of a better custom clip, or one from another setup or something....
i'm jus looking for suggestions.
here is a link to my site with pics and stuff:
http://extreme.teamslack.net/cpu/
thanks
