Results 1 to 7 of 7
Thread: timing???
    Nov 2004
    bandung...indonesia
    timing???
    im using kingston KHX3200ULK2/512.. how can i set the best timing if i wanna run @250Mhz?
    is there any spesification to set this things?
    hope someone could help me.... thank's
    Nov 2004
    Pensacola, FL
    alot of times the "auto" in your motherboard bios will get you close or at least started.
    After that you have to just keep bringing them down. it's trial and error.
    I would guess though 2.5-4-4-7 is a very "general" timings for PC4000 (250Mhz) unless your voltmodding some capable 3200 or soemthing along those links...
    Good luck.
    Also check the manufacter's specs,,,,they usually say what they can run at.
    XS Intel News & DČOL enhanced
    Nov 2003
    Netherlands
    2.5-3-3-7. uve got TCCD chips look at some GSKILL threads or the OCZ 3200plat rev 2
    Nov 2004
    bandung...indonesia
    gosh...
    still wont run over 220Mhz!
    but when i used BIOS from Merlin (nf7d_26).... runs @250Mhzx10
    with timing 7-3-3-2.5
    but when i flashed the BIOS back 2 the original.. only runs @210x11.. with some error message : disable the memory caching/shadowing.. turn of the ACPI by pressing F7.. ... ...
    what's wrong???
    Sep 2003
    Crazy Belgium
    Quote Originally Posted by deevo
    what's wrong???
    Wrong BIOS :p
    Why flashing back anyway?
    Be cool, be watercool!
    from Belgium, #1 Beer-country in the world!
    SuperPI && Pifast scores
    Nov 2003
    Netherlands
    ^^ do that, go in the bios.
    Nov 2004
    bandung...indonesia
    i did the fashin back coz temperature not friendly!!!
    btw.. does anyone tried BIOS from tictac for ABIT NF7-S rev 2? d10 or somethin?
    last time the temperature reach bout 48, idle.
    maybe i should buy watercooling? hehehehe
