+ Reply to Thread
Results 1 to 15 of 15
Thread: what would be best mobo foe fx55
    Registered User xttz's Avatar
    Dec 2003
    Mother Russia
    0
    what would be best mobo foe fx55?
    Asus P4C800-E Deluxe.
    Intel Pentium 4 XE - 3.8GHz @ 4.3
    Leadtek GeForce 6800 ultra@ ultra extreme 480/1250
    Kingston 1GB Kit HyperX pc4000.@ 2-5-2-2
    Vupichill LE
    GigaByte GA-8ANXP-D.
    Intel Pentium 4 w 3.6GHz @ 4.1GHz
    Corsair 1GB PC3200 DDR DIMM.
    Leadtek GeForce 6800 GT @ ?.
    Asus A8N32-SLI Deluxe
    Asus Extreme N7800 GT DUAL
    AMD Athlon 64 fx-60
    OCZ pc3800 platinum
    __________________________________
    Sorry my english is not wonderfull but im still learning it!!!!
    Dec 2003
    Mother Russia
    0
    thinking of trying amd sys
    Vupichill LE
    AMD Athlon 64 fx-60
    OCZ pc3800 platinum
    Xtreme Member Firefoxx's Avatar
    Jun 2004
    Bavaria,Germany
    0
    I think atm a MSI K8N Neo2 is the best choice, but everyone's talking about DFI S939 Mobos, so if u're able to wait, do it...
    Dec 2003
    Mother Russia
    0
    is that nforce4? so nf 4 better than 3rd one?
    Vupichill LE
    AMD Athlon 64 fx-60
    OCZ pc3800 platinum
    Dec 2003
    Mother Russia
    0
    and what is the best mobo from DFI S939?
    Vupichill LE
    AMD Athlon 64 fx-60
    OCZ pc3800 platinum
    Xtreme Mentor blinky's Avatar
    Jan 2004
    Berkeley/Stanford, CA, USA
    0
    the dfi board isnt out yet.
    right now the msi k8n neo2 is the best board for an fx55
    can you see the light? is it shining too bright? can you see the light at the end of the tunnel, i know i do, i know its true.
    Jun 2004
    Bavaria,Germany
    0
    MSI K8N Neo2 is NF3... no NF4 Mobo out, if i remember right..
    Dec 2003
    Mother Russia
    0
    msi k8n diamond is nf4 mobo and it came out i yhink and dfi i think i saw that its out!!! im no shure so its the best mobo the dfi becase alot of people saing its the best mobo!!! and can some one explain how much xxxx+ MHZ is fx55 2.4ghz i never was understanding amd clocks
    Vupichill LE
    AMD Athlon 64 fx-60
    OCZ pc3800 platinum
    Xtreme Recruit Jesus's Avatar
    Apr 2004
    Croatia
    0
    The DFI should be the best board ' cause of DFI reputation that is build by a lot of MoBOs which were the OC dream just mentioning Infinity KT400 ( a frind of mine has a screenshot of that board at 217!!!FSB, but its just a screen shot it crashed), Nf2 Infinity and LP ultra B, as well teh Lanparty UT nF3 754.
    Death is just a state of mind!
    DFI LanPartyUT nF4-UltraD, R.AD0 NBw.TR HR05-SLI+Glacial tech 92mm fan
    Venice 3000+, NBBWE 0601 (255×9) GPMW TT Sonic tower + noiseblocker 120mm,
    2×512MB Corsair 3200XL TCCD+BP PCB
    GeCube X1950XT,256MB, cooled by Zalman Vf700CU-water cooling under constuction
    Hitachi Deskstar T7K250, 250GB SATA II, 8MB cache
    Samsung SpinPoint S120 SP2504c 250GB SATA II, 8MB cache
    Seagate Barracuda 7 80GB, PATA, 2MB cache, 7200rpm in Metal Gear box
    BenQ DVD-1650, DL DVD-RW
    NEC ND-3520AW DL DVD-RW,
    Enhance ENS-0252A, EPS12V, 520W. moded to have a 120mm fan istead of the second 80mm. Ultra Monster
    Casetek 1018+120mm blowhole on top
    iiyama Vision Master pro 454
    Dec 2003
    Mother Russia
    0
    ok thx guys
    Vupichill LE
    AMD Athlon 64 fx-60
    OCZ pc3800 platinum
    Xtreme Member bypolar's Avatar
    May 2004
    0
    The best board has not come out yet. and if you really look at how computing works you will never be able to buy the best board. it will always be on the horzion.
    Asrock Extreme3 Gen3
    Intel 2500K @5.0 1.52V
    Thermaltake Frio
    4-4GB Kinston HyperX 1600's
    1-256Gb Crucial M4 SSD
    Xion 1000W (Made by Superflower)
    2-Evga GTX570 in SLI
    Antec DF-30
    Windows 7 pro 64 bit
    Just a regular guy, Not Xtreme!!
    If I sound STUPID!! it is because I am.
    Not everyone can be a Genius!!
    Xtreme X.I.P. MaxxxRacer's Avatar
    Aug 2004
    Los Angeles, Ca USA
    2
    amen to that bypolar. As of now the k8n neo2 is the best. I have one and it looks really pretty in the packaging.
    And saying the DFI board will be the best yet is a guess. There is NO info on it. no one has a darn iota if info on that board. As of now DFI is claiming that they wont make a 939 mobo at all. But that is most certainly a lie. Since it seems that you like nvidia, you might want to try waiting for the nforce 4 boards with sli to come out and pick up two 6800ultra pcie's.
    Dec 2003
    Mother Russia
    0
    can some one explain to me how AMD works? im talking about MHZ how to calculate speed in amd fx55 2.4GHz how much mhz it is in intel math? xxxx+? how do u calculate AMD?
    Vupichill LE
    AMD Athlon 64 fx-60
    OCZ pc3800 platinum
    Dec 2003
    Mother Russia
    0
    and is fx55 athlon xp socket becsae i have water block that for athlon xp and intel sockets!!!
    Vupichill LE
    AMD Athlon 64 fx-60
    OCZ pc3800 platinum
    Xtreme Member split's Avatar
    Sep 2002
    UK
    0
    Here is the AMD table.
    OPN Model Operating Freq. Package Operating Voltage Case Temp. L2 Cache
    ADAFX55DEI5AS FX55 2600MHz 939-Pin OμPGA 1.50V 63º C 1MB
    ADAFX53DEP5AS FX53 2400MHz 939-Pin OμPGA 1.50V 70º C 1MB
    ADAFX53CEP5AT FX53 2400MHz 940-Pin CμPGA 1.50V 70º C 1MB
    ADAFX51CEP5AT FX51 2200MHz 940-Pin CμPGA 1.50V 70º C 1MB
    ADAFX51CEP5AK FX51 2200MHz 940-Pin CμPGA 1.50V 70º C 1MB
    The default FSB is 200, with a 13 X multiplyer = 2600MHz
    All you really need to know is it's the fastest thing you can buy at the mo.
    It's socket 939, so you may need a new waterblock depending on what you have.
    See the difference here
    Avatar supplied by Major Slaughters sister
+ Reply to Thread
