I like the wavemaster so much because of its looks but is it small inside?Also how is the cooling since it doesnt have but one place for a fan.
Chris Smith
If you want a good solid case with tons of rep get a Lian Li 6x. By far the best / most reliable cases on the market
i seen them before but i dont like the looks as much as the coolmaster wavemaster
Chris Smith
http://www.newegg.com/app/ViewProduc...144-026&depa=1
http://www.newegg.com/app/ViewProduc...144-082&depa=1
Here's some ASPIRE cases, I've had good luck with their other products, plus I think they just look neat. Can you tell I like black and silver?
jjcom
gross!!!! do not get a premodded case!!!
they are poorly built and not well designed. The x-dreamer i have....i have to force the expansion cards to screw in, and the fan holes and built in grills are extremely poorly designed. with 28dba fans and a quiet cpu fan ( can go less than 28dba), it sounds like train.
here is a good case
http://www.newegg.com/app/viewproduc...129-120&DEPA=0
comes with a nice psu too. 2x intake and 2x exhaust. high quality. you can add a window with a fan and a blowhole fan if you like too
3570K ● Asus V Gene ● 8GB Mushkin DDR3-2133 ● EVGA 660 Ti SC ● Seasonic X750 ● 128GB Samsung 830 SSD & External 1TB RAID1
SupremeFX SPDIF -> MHDT Constantine DAC -> Darkvoice 336i Tube Amplifier -> AKG K701
whats wrong with trains? I can make mine sound like that....maybe need to invest in fan controller and cutting a hole for a 120mm fan...
What do yall think of the wavemaster case ?Does anyone know how good the cooling is.
Chris Smith
I really wouldn't suggest a Pre-mod. As stated b4 they are usually rather badly done. If you still want it ... google some reviews
Its not pre moded coolermaster wavemaster is what im talking aboutOriginally Posted by iljs
Chris Smith
I think he was talking about the cases I put up. Yeah, sometimes a premodded case can be alittle odd, but sometimes there done right and look nice.
Thermaltake are usually well done pre-mods. But, read some reviews of the wavemaster and make your decision based on multi-opinons :P.
http://www.hexus.net/content/reviews...lld19JRD01ODg=
http://www.pcstats.com/articleview.cfm?articleID=1552
http://www.cluboverclocker.com/revie...er/wavemaster/
Well i started thinking and i want some room in a case for moded and maybe watercooling and i looked at the stacker case and i like it but dont like the weight but i can live with that i think because i wont be takeing my pc anywhere.I like the door on the wavemaster and i dont because if you add stuff that looks good u cant see it unless you leave the door open so i guess it doesnt really matter to me.What do you guys think, wavemaster or stacker?
Chris Smith
The stacker will have all the room that you will ever need, its a well built clean looking case and Id get the stacker over the wavemaster if I was you
Where you think the best place to get one at because i dont want one with the defects like i heard some of them haveing and i heard newegg was still shipping the old ones.
Chris Smith
Well i got the cs stacker
Chris Smith
nice....i think im going to get the lian-li pc75 . courtesy of customer buying computer. he can get my x-dreamer craptaculous version # piece of crap
Yea i think coolermaster and lian makes the best case but i never had ethere.This will be my 2 computer ive built.
Chris Smith
well i got my stacker case.I open up the box and wow its big and looks sexy as hell.I thought i got the silver one but i orderd the black but i can paint it later if i want to.
Chris Smith
