Im thinking of buying either a 3200 or a 3500 90mm but which one of them would OC the best?
Depens if you get a good overclocking 3200+ or a good overclocking 3500+
Intel FTW!
Beanna
It's alwas luck.
The 3500+ can do more but also less.
Both can be grat (+3Ghz) but also the biggest .... !
Would say the cheaper one.
dnb-sets 4tw
Drum n Bass Arena ..
WPO Powerlifting
I got my 3500+ doing 265x10 24/7.
-=Vran=-
[SIZE=2]MSI 890FXA-GD70, AMD 1100T, 2x 4G G.Skill F3-17000CL9D, 2x XFX Radeon HD 6850 Black Edition 1GB 256-bit DDR, 180G OCZ PCI-e RevoDrive
vran- what vcore?
yeah i think i will get a 3200
more like what cooling?
i'd be interested in the outcome of this, as i'm probably going down this road soonish![]()
sky / s!p - we are oldskool, dammit.
now i orderd a msi something know it is the most expensive one and nfoorce3 and a 3200+ winnie![]()
Originally Posted by Snowman89
well, i ended up going with the Abit AV8 and a 3500+ should be up and running this weekend....we can compare and see who... "winnie"![]()
JoeCamel is FOLDing for... A CURE!!! 70+Ghz (please fold so i dont have to quit smoking. j/k)
6800 EX Conroe @ 4740 MHz (395 x 12) - - Dry-Ice in The Camel Pipe - - X1900 CrossFire - - @ 846/945 -- MachII cooled Slave XTX - mOUSE-pOT cooled Master - - ASUS P5W-DH -- V-Mods: MCH, V-Core, V-Dimm - - 700w "Mr Zippy" PSU - Corsair XMS 6400 CAS3 - 2x gig @ 494 MHz 4-4-3-1
my 3200 isnt too greatOriginally Posted by Joe Camel
2.4ghz at 1.55v
2.45ghz 1.67v
not tryed higher yet
but with 1.72v did a 32 sec superpi at 2.6ghz unstable tho for anything else
If i have to read one more "watercooling ram" thread im guna bring the damm roof down![]()
PC in a fridge idea comes a close second![]()
Mail me gmail
BAcon-->"my 3200 isnt too great" hehe I have a 3500+ that cant make it over 2350mhz that what I call aty cpu ;-)
Shuttle SN95G5
Wow Stinger join the "crappy winchester" club!
Mine has a top speed of 2400 MHz. Thats where it just poops out.
I am going to try just one more and hope for the best.
God damn, a 90mm process chip.. thing must be like 3 square meters big!![]()
2717MHz
RIG: 3500+ "Winnie" CBBFD 0441, XP-120 (lapped) 120 CFM, Abit AV8 bios 16, G-Skill (TCCD), ATI x800 Pro, ZM80D-HP (2 pipe)
settings: ("STOCK")(with Mushkin 222 V2 TCCD)
.....CPU.....................MEM.................V ID......
200x11 (5xHT).......2,2,2,6,10,16........475/450
....2200MHz............1:1 (ddr400)
....1000HT.................200MHz
settings: ("OC 2") G-Skill +OCZ DDR Booster @ 3.1V
.....CPU.....................MEM.................. ..VID......
247x11 (4xHT).......2.5,3,3,8,10,16........475/450
...2717MHz............1:1 (ddr400)
....988 HT............247MHz (cpuZ)
Benches:
settings: ("STOCK")
.....AquaM...........01..........03..........SIS CPU......SIS MEM...
GPU..8787........25,269.....10,419.......10377.... ....5051/5230
CPU..10,685..................................3539/4616
.......62,277
settings: ("OC 2")
.....AquaM...........01..........03.........SIS CPU.........SIS MEM...
GPU..10,635.....28,213.....10,889......12,563..... .....7268/7180
CPU..12,718................................4285/5589
.......75,006
lol I don't even that would be possilbe to make a chip on that bad of a process, I mean the chip would be the same size as the wafer, lolOriginally Posted by LANjack
Why don't go for the 3500+ Newcastle. IMHO their better then the 90nm ones. Most memory doesn't go as high on a 90 nm as it would do on a 130nm, and the results I have seen so far on PhCh are kinda disappointing. I'd expected to see more 3.2 Ghz shots (and benches) like Charlie on DI.
Those 90nm core's run fast on air or water, so my advise would be to decide based on your cooling and memory needs.
I don't know if the slow memspeeds are somehow related to the subzero temps, but in my experience it made a huge difference...
I must say .. u do have B@lls!! :P
Taking the path of VIA and Abit .. with the AV8 (did u see the horde of problems on the Abit forums!!)
Still ... part of me wants to stick with Abit as I have had numerous issues with past MSI boards (actually swore never to buy MSI again)
By the looks of it ...its the onli NF3 mobo out there and is actively hitting high FSBs.
Whats the MAX FSB u can hit with the AV8?? Care to post any screenies??
I'm sure your G-Skill partnered with your late production winnie could be prime canidate to prove that there is life in the AV8 (VIA platform)....
Joe, what voltage are you running your 3500 winnie at to get 2.7ghz..?? Its the one vital thing you left out. ITs possible there is still some room in that chip!
Originally Posted by geosin
as happy as i am with my NF7-s, i just HAD to give Abit a shot with 939!
as this is my first 64 setup and only just now starting to understand how to tweek it, ill have to ask "which FSB" mem or CPU... i MAXed out the RAM @ 275 MHz (1:1 with a 7x CPU) never really tried to max out the "CPU FSB"...but with the little testing i did, i wasnt able to get 300 x 7 to boot even setting the mem to "safe/stable" speeds...
im still worken out the bugs on P95 stability...IMO it aint stable till it can do 1-2+ hours of P95 AND bench: 01,03,Aqua,SIScpu,SISmem...247 could bench but couldnt do P95 for more than 10 min...as of right now im 40min into 245x11 then ill get back to 247.
THIS is my thread on OC for more "up-to-date" info...
BTW i could post and CPUz 2800+ but wasnt stable
1 hour 8 min and it errors...
this is running @ 1.600V again, as ive only had a 64 rig for about 48 hours now im still learning...Originally Posted by MaxxxRacer
(LOAD) temps are in the range of 54-60C... she's P95ing @ 54C as i type (on sig rig) room temp is a "cool" 18C (65F)
i never really noticed much of a "settle-in" with my 2600 (sig) and AS5 but now with this IHS, i can see it FORSURE!
ill be hooking my 2loop (see/click in sig) up to this "soon" although i would LOVE to get my MachII on it...but im not going to spend all the time setting THAT up if it turns out to be the "Winnie" that has the "cold-boot" bug...
yes, i have a (stock) MachII sitting in the corner of the room with a 64 mount (still in the box) not doing a thing butme to hook it up
after i killed 1 NF7-s with my prommy, i decided to "step back" from extreme cooling...(sig chip did 2900+ with it)
hate to post SS this way, but full size it would F-up the page soo much...
