Results 1 to 21 of 21
Thread: "Dummy" heat load, any ideas?
    Jun 2003
    I would like to have a way of testing my direct die systems without having to hook them up to an actual cpu, anyone have an idea of how I can do this (yes i've already considered the TEC option). I was thinking of converting something like a large soldering iron into a heating element that could be attached to the block. Bowman has used industrial heater slugs (essentialy large resistors that put out 100w of heat) in a copper spreader to simulate a heat load, but I was unable to find anything of this sort at my local electronics store.
    I'm sure there's probably a simple solution to this but I haven't found it yet.
    @pcice - what did your heatload tester come from?
    HVAC/R Engineer
    Nov 2003
    I use a solid copper block with three 100 W resisters in it and it is completely insulated and mounts directly to the face of the block. The resistore can be wired in series or parrellel
    May 2004
    Perth, Western Australia
    that sounds cool, i was thinking of a 100w lightbulb bhind a copper plate
    Quote Originally Posted by bh2k
    sorry m, OI'm a bit drunkz!
    Air benches with 3000+, DFI nf3 and 6800GT 2001SE: 26312 3d03: 13028
    Jun 2003
    Quote Originally Posted by chilly1
    Where'd you buy your 100w resistors? Are they available online?
    HVAC/R Engineer
    Nov 2003
    Got them on EBAY for 8.00 they are wire wound resistors in a stainless tube.
    XS - Extra Strong
    Aug 2003
    Toronto, Canada
    Offtopic: I think they used those things on older dryers... I recall being shot with something like that a couple years back (overheated or was miswired and shot about 10 feet across the room and burnt through my pants and burnt a little line in my leg)
    Lesson learned, when your dad says "hey come look, i got it working" watch out.
    -Phenom2 x6 1055 @stock
    -8gb ddr3
    -Gigabyte UD3
    -Geforce 7900Gt 755/1863 1.562v vgpu
    -OCZ Powersupply 600w
    HVAC/R Engineer
    Nov 2003
    No these heaters are 100W and 3/4 inch llong with 1/4 inch diameter.
    Jun 2003
    I looked around ebay but couldn't find any 100w round heatercartridges that weren't huge, but I did see two 100w resistors that could be bolted to a heat testing block, would that work? What's the difference between a 100w 5ohm resistor and a 100w 8 ohm resistor (for example)?
    Aug 2003
    Netherlands
    Only the resistance
    Do you want to use them on 12v?
    Then you would need 100W/12V = 8.333A
    12V/8.333A = 1.44Ohm Resistors (1.39 or 1.5 for example)
    Good luck
    Pifast:
    Socket 754 3700+ Clawhammer action:
    39.64sec 11*285 2.5-3-3-7
    Now Pifast @ 3306MHZ !!! 37.72sec World record!
    Now SuperPi 1M @ 3306mhz 26.922sec World record!
    Ministry of Overclocking Contests
    Jul 2004
    Aquarium heater?
    Jun 2003
    I'd prefer to run them on 120v ie 2x 100w heaters @ 120v each.
    Oct 2004
    Crazypc.ro
    ''Aquarium heater?'' depends of size and shape mine is like 2cm diameter 40cm long so u must improvize somethings so is not good i say.
    What about a hairdryer?
    Personaly i will go with the TEC
    Edit: for the dryer, put a coper cooler like thermalright with tha side that is suposed to stay on the cpu on the evap yes that side on the evap and then put the dryer to blow on the other side! I dunno if its works, happy if some1 will try it and give me a pm or post it here!
    Aug 2004
    NYC
    i used a TEC for that once...
    "Monolith" - [ Xeon W3540 (4.22) - Rampage 2 Extreme - 12 GB Ripjaws 1600 - GTX 570 - 120 GB OCZ Vertex - Antec TruePower 750W - Corsair 700D - Apogee XT CPU Block - XSPC 360 Rad ]
    Old Box - [ E4600 2.4 @ 3.7ghz (11x335) - P5W-DH - 4gb Gskill @ 893mhz - Radeon 3850 ]
    Jun 2003
    I actually did do the hairdryer method a few days ago.. pointed it on low at a heatsink attached to the evap. The problem is the hairdryer puts out 1500W of heat, lol. I need something a little bit less powerful.
    Oct 2004
    Crazypc.ro
    Quote Originally Posted by gkiing
    hahaha now i realize that i never use the hairdryer but cant u set it to lower speed the hairdryer's fan so that the wattageis lower? 750w lets say, lol 1500W!!!
    Anyway the peltier is the thing to use!
    Ps what ?hp compressor will remove lets say 750w at -40c lets say? 1, 1/2? thx
    HVAC/R Engineer
    Nov 2003
    Bowman sent me some resistors, both were 100W dean surface mount resistors, a little hard to mount but once done could be insulated and attached to a processor for accurate heat loads.
    Aug 2003
    Netherlands
    I hope you mean "to the cooling system" instead of the processor
    Pifast:
  18. #18
    XIP - can sit on his hair
    Jun 2002
    Wakefield, West Yorkshire, UK
    Hotside of 174w 24v TEC attached to prommi head. Maze4-1 Waterblock with coldplate removed attached to coldside of TEC. Warm water pumped thru cold side.
    Voila. Approx 150w (I think!!) load simulator (just keep the water at as constant a temp as possible)
  19. #19
    Jun 2004
    I use wirewound clad resistors, only rated for 20 watts but I run them over 100 watts....remember the power rating on such resistors is with ambient temperature cooling, when attached to a phase change setup you can easily push these smaller resistors to 100 watts. I've added a thermal trip that stops them burning out if the temp gets too high.
    I prefer to use such smaller resistors as it more accurately simulates the concentrated heat output of a cpu, and gives you a more accurate load capacity reading - even insulating up your load block still results in some of the heat being lost as thermal radiation, so the smaller the block the better.
  20. #20
    Jun 2004
    Peltiers don't make accurate loads, in a basic DC connection such as that, as their power consumption changes by as much as 30% depending on their hot and cold side temp's.
    However they can be made to give very accurate heat outputs with monitoring circuitry and PWM power modulation.
  21. #21
    Jul 2002
    In CyberSpace
    Made my own heatercore & a friend helps make the critcal part that completed it off.
    Rated against the powersupply I intend using I'll have about 400Watt on tap all in a 1" by 2" core.
    The rest i'm afraid is not for show as this is a do it all test die simulator
    any heatsink/waterblock or phasechange and accurate simulation of core
    height for pressure purposes and effects when pressure is increased.
    Tested to 65W and hit 220C bare wired up with cable that withstands 800C
    not per the pics below thats just standard heavy duty and it melted anyway lol :chuckle:
    New specs to appear here >.< sometime soon.
    in the mean time i'm using me shuttle
    tis fast enough for now.....
    <doh in me dream tis slow> no vmod / no PSU mods / no phasechange how can it be fast
