Page 1 of 5 1234 ... LastLast
Results 1 to 25 of 107
Thread: GSKILL PC4400 TCCD at CAS2.0
    Bandwidth Freak
    Dec 2003
    Talking GSKILL PC4400 TCCD at CAS2.0
    I read the topic about high voltages on TCCD memory, so i tested with CAS2.0. And it worked!!
    It seems that the TCCD memory dont like high voltages with high timings, i get lots of errors with CAS2.5 @3V and zero with CAS2.0 @3V.
    So lowering the CAS latency gave me the oppertunity to play with more Vddr.
    Great discovery i guess..
    Here some screens with info 2-3-3-7 3.0v
    3400+ AX
    DFI Lanparty
    2x 512MB GSKILL PC4400 " TCCD 431"
    Jul 2004
    France
    have you try with CAS 1.5 or CAS 1 ?
    My PC2700 noname ,go up more with CAS 1.5 or CAS 1 ,i don't know why ,but it go over 270 with 1.5 and only to 263 with CAS 2
    French Overclockers roxxxxxx
    OCM Team addict
    Mar 2004
    Nice! did more or less voltage effect the Cas2 at those speeds?
    Xtreme 3DMark Addict
    Sep 2003
    too bad cas latency does not matter on a64. My friend rukkor sure will be supprised though, he says no ram will do cas 1.5 over 166fsb. what I really am interested in, has anyone gotten ras-cas1? like 2-1-1-7 timings?
    3000+ Venice 240x9=2.16GHz(ondie controller limit) 2x512mb patriot tccd ram
    9700pro at 325/310 runs all games buttery smooth!
    9700(8 pipe softmod, 128m) at 410/325 23821 at 325/310 21287 at 275/270 19159
    9500(4 pipes, 128m) at 420/330 18454 at 275/270 13319
    9500(8 pipe softmod, 64m) at 390/310 19201 at 275/270 16052
    9500(4 pipes, 64m) at 400/310 16215 at 275/270 12560
    3dmark scores with Ti4200 and Ti4800se
    Ti4200 at 340/730 19558 at 300/650 18032 at 275/550 16494 at 250/500 15295
    3dmark scores with older gpus
    Ti500 at 275/620 14588 Ti200 at 260/540 13557 MX440 at 380/680 11551
    IRC Operative
    Aug 2003
    Tampa, Florida
    Quote Originally Posted by overcrash86
    This guy hasn't got a clue lol
    CPU:
    Intel i5 750 @ 4200mhz 200x21 1.344v
    Cooling:
    Corsair H50
    Mobo:
    Gigabyte P55-US3L
    Memory:
    4GB Corsair XMS3 9-9-9-24
    GFX:
    ASUS HD5850 850/1200 1GB
    Dec 2002
    Quote Originally Posted by Geforce4ti4200
    And this guy does....
    If cas doesn't matter then why does everyone strive for cas 2 on A64...
    Riggghhhttttt....
    - LL V1000 - GA965P-DS3 - Intel C2D e6420 3.22GHz - 2GB OCZ 6400 Plat Rev 2 - GeForce 8800GT KO AC S1 - 500w Enermax Liberty -
    Sep 2002
    Quote Originally Posted by Firelord-OCHW
    Riggghhhttttt....
    Actually cas2 or 2.5 really doesn't matter on my DFI. I've tested cas2-3-3-5-1t and cas2.5-3-3-5-1t and noticed no difference. If anything 2.5 actually gave me higher 3dmarks. Of course maybe my DFI doesn't take advantage of cas2.
    I have some bh-5 chips coming on Tuesday so looking at some 270htt 2-2-2-5-1t action to compare with.
    Asus P5W64WSPro/Xeon 3060 SS 9x467/TeamXtreem 667 2GB/Patriot PC28000XBL 1GB/Sapphire X1800XT/w PE bios/OCZ PowerStream 520w/150gb Raptor/CPU cooled by AquaXtreme MP-05 Pro Limited Edition, BI GTX 240/MCPSwiftech655/Masterkleer 7/16IN
    Jul 2004
    kakaroto you are so lucky, have best BH5 I ever seen, now these superb TCCD; congrats m8
    Dec 2002
    Quote Originally Posted by RacerX
    I found I lost a chunk of bandwidth at CAS2.5 with my BH-5 on a k8N neo (at 1T) and was the diff between smooth and jerky in some games
    My DFI won't evem boot @ 2.5!
    Xtreme Mentor
    Jan 2004
    Berkeley/Stanford, CA, USA
    no.... you didnt, it may just seem that way but u didnt lose a chunk of bandwidth
    can you see the light? is it shining too bright? can you see the light at the end of the tunnel, i know i do, i know its true.
    Jul 2003
    Belgium (Brussels)
    I'm using my bh5 @ 270 1.5 2 2 1 7 12 1T in dual
    - MSI K8 Néo 2 54G with bios 1.8
    - Venice 3000+ 0515 FPCW @ 2875Mhz (1.65v)
    - 2*512 OCZ EL Series Dual Channel Platinum DDR PC3200 rev 2 @ 580Mhz 2.5 3 3 7 1T dual @ 2.85v
    - Asus X800XT PE @ 627/649 with Dangerden Maze 4
    - OCZ Powerstream 520w
    3dM01: 37342 - 3dM03: 15404 - 3dM05: 7086 - Spi 1M:26s - Spi 8M:4m 58s - Spi 32M:23m 49s
    Dec 2002
    Quote Originally Posted by blinky
    No because I didn't test it to make sure that it didn't make a difference so I could just come out with BS!
    I did my testing (SANDRA, AIDA32, 3D'01SE and 3D'03) and there was deffinetly a noticable difference in all.
    So yes I am right thank you
    Jul 2004
    The Netherlands
    kakaroto, is your mem stable at 260MHz or is it just screenshot stable?
    and what kind of bandwidth are you getting at 260MHz 2-3-3-7?
    great find tho'
    XS News
    Aug 2004
    Sweden
    My TCCD does 275 with 2-3-3 at 3.5 volt.
    But its only cas 2 that like that volt.
    Everything extra is bad!
    Jun 2003
    Norway
    With my BH5:
    AN50R cas2.5 to cas2 yields NO difference
    K8NS cas2.5 to cas2 yields NO difference
    K8NS Ultra939 cas2.5 to cas2 yields NO difference (Except cas2 gives higher clocks)
    A lot of ppl have confirmed that cas2 or 2.5 makes no difference in performance on A64. Are you sure you diddn´t change any other settings? Same thing with Intel P4 actually. VERY small/No difference.
    LOL
    You should try to be a bit more humle. No one likes a smartass.
    Bandwidth Freak
    Dec 2003
    Quote Originally Posted by Playful_Buffalo
    more voltage gives better stability with CAS2.
    hahaha, your very funny guy! 2-1-1-7. You can be to optimistic about TCCD.
    A64 do like low latency, especialy in 3dmark and superPI/Pifast.
    The differency is not much, but he thats the purpose of tweaking dude.
    Quote Originally Posted by WolfF
    Thanks,
    Quote Originally Posted by Jack
    great find tho'
    260Mhz is just some screen yet. with 250MHz it get 0 errors in memtest, but 255~260..10K..maybe it need some higher voltages...
    Quote Originally Posted by Ubermann
    Woow thats awesome, try some higher voltage then. (I still using the 3.1v bios of the DFI)
    What is the 24/7 voltage limit of TCCD?
    Jun 2004
    I think 3.2-3.3V?
    E5200
    Asus P5Q-VM
    A-DATA 2x2GB
    Zotac 8800GT
    500W Seasonic
    Quote Originally Posted by trakslacker
    har har! Geforce strikes again with one of his "theories"
  18. #18
    Jul 2003
    The Netherlands
    I've tried the cas2 setting myself but I got only like DDR500 Mhz with 2.85V. (2.0-3-3-7-1T-DC). Since I've got the 437 TCCD ships on my GSkill this may not work as wel for me as it does for Kakaroto.
    After that I tried runnning @ cas2.5, also with 2.85V and timings set at 2.5-3-3-7-1T Dual Channel also.
    That got me this result:
    *Clickable*
    So maybe the 437 chips like cas2.5 and high volt better
    Can anybody confirm this??
  19. #19
    Jun 2004
    Olot (Girona)
    I get higher clocks at 2'7V than 2'85V.. now 280 2'5-3-3 1T at 2'7V wich gives me 8K mb/s.
    PD: Geil Ultra X PC3200, unknow TCCD revision.
    || Core 2 Quad QX6850 ES @ 3.5Ghz 1.35V || Thermalright Ultra 120 || Asus P5K3 Deluxe || Gskill F3-12800CL7D-2GBHZ
    || XFX 8800GTX || Dell 2005FPW 20" || Ultra X-Pro 750W LE || 3 x WD 320GB SD + 1 x Hitachi 500GB
  20. #20
    Oct 2004
    Orlando, FL
    Can we get some good pictures of the chip numbers
  21. #21
    Xtreme Enthusiast p4z1f1st's Avatar
    Feb 2004
    he's simply right.....it doesn't effect apps nor games more then 1-2%....
    ----- AMD K6-2 300 "Chomper" xxxxx xxxx xxxx /// 300 MHz @ 2,200 V -----
    ----- AMD Athlon XP 1700+ "Thouroghbred B" JIUHB 0306 MPMW /// 2400 MHz @ 1,900 V -----
    ----- AMD Athlon XP-M 2500+ "Barton" AQXEA 0327 UPMW /// 2450 MHz @ 1,850 V -----
    ----- AMD Athlon XP-M 2600+ "Barton" IQYHA 0401 XPMW /// 2500 MHz @ 1,750 V -----
    ----- AMD Athlon 64 3000+ "Newcastle CG" xxxxx 0418 WPMW /// 2600 MHz @ 1,600 V -----
    ----- AMD Athlon 64 3200+ "Winchester D0" xxxxx 0433 SPMW /// 2750 MHz @ 1,616 V -----
    ----- AMD Phenom II X2 555 BE "Callisto" xxxxx xxxx xxxx /// 4080MHz @ 1,375 V -----
    ----- AMD Ryzen "Zen" xxxxx xxxx xxxx /// TBA @ TBA -----
  22. #22
    Bandwidth Freak
    Dec 2003
    Quote Originally Posted by LANjack
    these are the modules:
  23. #23
    Oct 2004
    Orlando, FL
    431 and F as I suspected!
    Thanks for the photos and confirmation.
  24. #24
    Bandwidth Freak
    Dec 2003
    today i tested with 3.2v and higher, it gave me NO improvement.
    250MHz 2.9v 2-3-3-7 = 0 errors in memtest
    255Mhz 2.9v~3.3v = 10000 errors in memtest
    Controller problem? i think so...
  25. #25
    just bacon
    Jun 2004
    cool, just ordered some of this kit from excaliberpc.com
    Should be here by end of week to me in the UK
    was guna get some OCZ 4200 but in Uk will costa bomb and excaliber wont sell it to me with paypal as its $2 over the limit and not paying fees for a transfer
    So got some Gskill coming at £178inc (same price as crucial ballistix (sp) here in the UK)
    Dam cheap hpefully get good uns
    If i have to read one more "watercooling ram" thread im guna bring the damm roof down
    PC in a fridge idea comes a close second
    Mail me gmail
