heres the deal,
with the system in my sig, when i raise the FSB i lower the HTT and i increase the RAM voltage however i seem to hit a wall at 220mhz
i moved my SATA drives to the 3 and 4 channels so that they're hot the problem, i lowered the CPU multi so thats not a problem now either.
what happens is that to get a higher fsb i need to lower the RAM an whole generation, for example to get a bus betweek 220 and 230 i need to put the ram at DDR 333 rather than 400, which is fair enough.
but when i have to lower the RAM to DDR 200 to get a fsb of 240 it gets a bit silly.
100 mhz RAM with a 240 fsb!!!
rasiting the bus 40mhz means i have to half the speed of my RAM to be able to boot.
any ideas..its got me stumped.
could it be that the mem controller on the CPU needs more voltage? so i need to up the Vcore?
