Page 2 of 2 FirstFirst 12
Results 26 to 31 of 31
Thread: Got me a 2800Mhz XP2400+ Today
  1. #26
    Nov 2002
    Wellesley, MA
    KICK ASS JOB! kudos opp
    -2600 mobile AQYHA 0346 XPMW Y @ 2600mhz 1.9v (hits brick wall after this)
    -Water Cooled- Dtek Spiral and Dtek NB Block, Ehiem 1250, Dtek Rad... around 43C Full Load
    -DFI Infinity
    -2x256 Twinmos BH5
    -Geforce FX 5900 XT
  2. #27
    Nov 2002
    Texas
    That is so close to 20K...very nice OPP
    Abandoned [H] 11/14/02
  3. #28
    Jun 2002
    NJ USA
    Freaking Outstanding... Your reputation is well deserved
    Clocked and Unlocked and ready to Rock
  4. #29
    Oct 2002
    I can run as High as 204 with the Radeon as far as completeing 3D. I can do 210 into windows but no 3D. And there are no artifacts. The reason I run 3D at 198 is that my card with a v-mod will do 500mhz at 198. The minute I go higher the card v-mod won't work so I can only do 450 without it. It's a strange problem or I'd be running 3D at 200 if the voltage mod would work and that would be some high scores
    Have you tried booting 198, then using SetFSB to see if you can go higher and still use the v-mod?
    Current Setup
    Celeron 2.4 @ 2.88 on Gigabyte 8IPE1000 Pro 2, 2x 256MB PC3200 DDR, 32MB Geforce 2 GTS
  5. #30
    Xtreme Recruit
    May 2002
    Massachusetts
    This constitutes my subscription to this thread so I can see how it turns out.
    Oh and damn fine job, sir.
    The only way to have real success in science ... is to describe the evidence very carefully without regard to the way you feel it should be. If you have a theory, you must try to explain what's good about it and what's bad about it equally. In science you learn a kind of standard integrity and honesty.
    --Richard P. Feynman
  6. #31
    Overclocking Guru
    May 2002
    SoCal, USA
    Yea I tryed that, didn't help, 198 was the limit with the Card v-mod.
    OPP
