scored 28300 or so with 4400mhz, ramspeed (mixed BH5-6) 240 @ 2-2-2-5.
GPU (XT-PE)was only at 550/600 (no time to mod yet).
I find that low, if you see the specs.
what is wrong here ?
http://service.futuremark.com/compare?2k1=8208659
Dell XPS M1730 - X9000 @ 3400mhz-4096MB 667MHz DDR2 - M8800GTX SLI- 17"WUXGA+
EVGA E762 4Way SLI Classified - 980X @ 6Ghz Lnē 6GB Dominator - MSI 5870 Lightning
WWW.MADSHRIMPS.BE - Being Mad Doesn't Hertz You
We all know that a p4 isn't the 'king' of 2k1. I think it's a normal score 4 your specs.
But if jah wanna get 30k ,just bench with windows 2k /2k3 that will give an extra 300-500 points, also try windows tweaks / edit your gva-card bios... and use a v-mod... don't worry you'll get you 30k
Gtz L@TrO,
ehm, W2K for Intel ?
it's a known fact that XP is the OS for Intel, W2K/3 for AMD.
I'll do a downgrade
2K: http://service.futuremark.com/compare?2k1=7948574
XP: http://service.futuremark.com/compare?2k1=7934871
Everything was fully tweaked. The CPU was acctually clocked lower in the 2K test. XP is not good for anything.
For those of you about to post:
Take a look at this -> http://service.futuremark.com/compare?2k1=8129818
This guy has 30k with his p4, but thats with 675/641 and 4.6ghz. I think you just need some higher clocks.Try to edit your bios and give some more volts, a v-mod will also help a lot (ask colin if he whants to drink a beer at your home :p ).Also try to get some more bandwith (maybe your tccd sticks will do better...).
I beat him in car low/high and almost in Lobby low/high.Originally Posted by L@TrO
I'll ask Colin to drink a with me, after he has done the mod
did what you asked :
http://service.futuremark.com/compare?2k1=8221161
29688
any help to crack 30K ?
ricky's special trick maybe? read the thread about OPP's trifecta.
fsb is very important in 2k1 benching. just try to clock your fsb higher
AMD 64 San Diego 3700+ @ 3050MHz | DFI NF4 LanParty Ultra-D | 2 x 512MB A-Data Vitesta DDR600 + 2 x 512MB Mushkin BL2 BH5 + 2 x 256MB Kingston Hyperx BH5 | Asus Geforce 6200GE TD @ 8 pipe 550/650 | 2 x 200GB Seagate 7200.8 NCQ SATA HDD Raid0 | 530 Watt TAGAN 2Force |
XP is faster for Intel, period.
System
ASUS Z170-Pro
Skylake i7-6700K @ 4600 Mhz
MSI GTX 1070 Armor OC
32 GB G.Skill Ripjaws V
Samsung 850 EVO (2)
EVGA SuperNOVA 650 G2
Corsair Hydro H90
NZXT S340
It is?Originally Posted by craig588
