Originally Posted by blinky
i haven't do mods yet, however...
i hit 435/340 3dmark stable on my card todayOriginally Posted by Malachia
thats with crappy air too (vga silencer)
got anything to counter that?
can you see the light? is it shining too bright? can you see the light at the end of the tunnel, i know i do, i know its true.
wich kind of bastard
ok, the first that reach 20k is crazy man
20K should be here on sunday, and 435/340 is with NO vmods eitherOriginally Posted by Malachia
this is fun.
cant wait til we both get vapor cooling on the gpu
435 without mods???
YEPOriginally Posted by Malachia
but with tec on gpu, i hope
no just air, we'll hit 450-460 at least on the tecOriginally Posted by Malachia
my dear friend, now i s the moment, plz tell me all the mods/tweak you know, in a month cpu will be @-80 and vga @-50
here you go...Originally Posted by Malachia
i think these mods are unreleased until now
hem...haw i can use them???
EDIT
what pot you used for VREF and VDDQ???
20K is a safe bet, but you could probably get away with using 10k ones.Originally Posted by Malachia
id use 20k for all three, u can always get lower resistence, but with a 10k u cant get higher than 10k, lol
lol, and for the core what pot you used????
10KOriginally Posted by Malachia
ok, then, i su 10k for the core as in the first pic, then 20k for all the other mods in the last pic....
sounds good, cant wait for resultsOriginally Posted by Malachia
chopper will arrive in a week or two, r404 for the prommy next week...
ah, and will arrive also an AS8 and an E0
here you are
thats a very neat job !!
in a day or two i will complete the mod, now i am working on cooling....
Has any one did +5v and ground booster mods on their 9500pro? And how about adding caps for stabillity? I can get my 9800se 9500propcb up to 400/375 without mods, but when did the vgpu and vmem a while ago i had to set my clocks lower than before :S . I've got watercooling on my gpu and good mem cooling so i think the internal power circuit can't deliver the amps to my gpu and mem at high voltages.
done!
now, vgpu&vddr all ok, vddq and vref didn't seem to wok....i lower trimmer but nothing changes....
i tried soldering wires directly to the solder points on teh back of the card, and it didnt do anything for my clocksOriginally Posted by <Wouter>
i actually had power problems as well, and they were solved by getting a higher watt power supply. hehe
i would suggest adding caps though, it might help
