Pats his An50R...
Pats his An50R...
Opteron 165
Dfi NF4 Expert
4x1 1GB twinmos PC 3200
XFX 7900GT 550/1500
Eric(back at the office) ran 4V on some although that may be a little excessive.I will ask a few questions for you and hopefully get some answers.
Got a problem with your OCZ product....?
Have a look over here
Tony AKA BigToe
Tuning PC's for speed...Run whats fast, not what you think is fast
Is it true that these are unmarked winbond chips of some sort? Perhaps the leftover inventory winbond had before closing down?
A wiseman once said, "If Bible proves the existence of God, then comic books prove the existence of Superheros."
he allready said repeatedly that they are not going to release what ic's these are. give the guy a break allready.Originally Posted by thephenom
I5 2500k@4.7ghz--Asus P8Z68-VGen3--4x4gb Gskill Ripsaw 1600 --EVGA GTX570--Crucial m4 128gb SSD--Corsair TX950w--Corsair H100--Corsair 800D
Scores are all 4+years old. updates soon.
All scores are outdated
24/7 3dmark06 6841
24/7 3dmark05 13357
24/7 3dmark03 22979
Very Mild 3dmark01se 55225
24/7 Aquamark 3 136020
More Voltmaster stuff....2-2-2-10 at 260FSB on the MSI K8N Neo 2.
that's real nice, is that 260 2-2-2-10 at 3.2v?!
Looks a bit like Mushkin TCCD...
TCCD 2-2-2-5 @ 255mhz @ 3.3v
VX/UTT Voltage Scaling, please contribute...
10x260 _ 1T-2-2-2-8-7-15 _ 3.3vDIMM _ 1.75vCORE
Mobile 3400+ CG 0437XDPW
DFI LanParty UT
XP120 w/ 120mm Thermaltake Thunderblade
2x512MB OCZ VX
BBATI 9800np w/Infineon
PC Power & Cooling 510w Deluxe
NICE!
ETA when it's going to be available ?
Or are you guys just testing the waters ?
Asus P6T Deluxe, Core i7 920 @ 4.1ghz, Corsair Dominator Tri channel 1600Mhz
Evga GTX285, Raptor 150GB, Corsair HX620
Apogee GTZ, PA 120.3, CM Stacker STC-01, DDC 3.1 MCP355/XSPC top.
Win Vista Premium X64
testing the waters for now ,
OCZ employee and proud of it.
If you have actually personaly experienced a problem with a OCZ product that was not solved quickly by our wonderful support staff I would like to know. Feel free to PM
I am overclocked!
"Posted on Mar 30, 2005 at 1:35 AM by StormGod
In soviet Russia memory overvolts you! "
doesnt the dfi use the 5v rail to create vdimm? 0_oOriginally Posted by Shade00
and be carefull with the 3.3v rail! bowman said he killed several a64s with a too high 3.3v rail of 3.6/3.7v!
and those results look really nice! really really nice!
what will the average sticks do with 3.2v? 250 2-2-2? 250 3-2-2?
or is this the result from an average stick of those ic's?
Originally Posted by saaya
the nf2 boards did. but the new dfi UT uses the 3.3v rail. there are modded bios that will let you use vdimm .1v less than your 3.3v rail is at.
Specs
Asus 780i Striker II Formula
Intel E8400 Wolfdale @ 4050Mhz
2x2GB OCZ Platinum @ 1200Mhz 5-4-3-18
MSI 5850 1000Mhz/5000Mhz
Wester Digital Black 2TB
Antec Quatro 850W
Cooling
Swiftech Apogee
Swiftech MCP-600
HardwareLabes Black Ice Extreme 2
Audio Setup
X-fi w/AD8066, Clock mod, & polymer caps > PPAV2 > Grado SR60 & Grado SR325i & Beyerdynamic DT770 Pro & Beyerdynamic DT990 & AKG K701 & Denon D2000
This was an average pair. Most shouuld be able to do this speed on the MSI board anyway. On the P4C800 the max speed is quite a bit lower..."only" 225.Originally Posted by saaya
Actually, I think I may have been capped at the max our MSI Neo2 could do, as I have just found out that I can't get anything to work over 260 now.
So it is possible that it could go even faster. It'll have to wait for a new Neo 2 though. I'll post when I get the new board in.
EDIT: Also, this was with a pair of modules (note the dual channel in the pic)
Nice but only 5 loops of #5 test is hardly considered stable.
Care to post a screenie with 50+ loops of #5 done when you get the replacement mobo ?
We will do...the more you juice em up the higher they go.Originally Posted by Nanobot
Tony AKA BigToe
why are the aidia results so low comparatively?? running in single channel.. and is that 2-2-2-2 timmings!!
Weird about the everest results , exspecialy considering AIDAlatency score is so good
I am overclocked!
whats wrong with sciencemark? always thougt its the best alternative fro sandra...
They are not that low really, remember this is 1 modules single channel.Sandra buffered is FSB driven more than bandwidth, the unbuffered is bang on though as my EB at 280 gives 2600+.
The everest latency got me though, thats the lowest i have ever seen.
Tony AKA BigToe
didn't, errm, was it bigtoe when he basically announced the plat rev 2 and the plat 3700 say both were tccd? isn't that what ryan is pointing out, best stuff goes in the higher rated ram? If thats the case then shouldn't everyone be buying that and not the 3200 rev 2 so much?
(can't remember if ryan tccd talk was last page or other thread, went from one to the other and canne remember)
Mail Me | 3500+ , dfi sli-dr, g-skill la, 2x6800gt, 600w pcz, stacker case, air cooled
Hi Bigtoe,
I recieved one of your ddr boosters in the competition ran on this site recently. Thankyou very much . I'm about 35 minutes from Manchester city centre, wouldnt mind meeting up if you have time to discuss optimising ram based on your booster coupled with sub zero temps. Have any experiments been done with ram at those temps?
Regards
John.
so did OCZ drop these or what?
Specs
Antec Quatro 850W
Cooling
Swiftech Apogee
Swiftech MCP-600
Audio Setup
what makes you think so?Originally Posted by WeStSiDePLaYa
well tccd is doing really well atm... i dont think there is much point in this
Unless its quite a bit cheaper....Originally Posted by enzoR
I dont wantto pay for TCCD, its not worth the money over my Bh5.
We haven't dropped it m8, TCCD does 245+ 2-2-2 when rammed with voltage, this stuff just keeps going...260+ with ease and im sure you guys will do even better
Tony AKA BigToe
Does this mean it will be released ?
Sorry to ask again but I'm going BH-5 route if the *OCZ PC3200 Voltmaster LE Gold * (a seems like that would be a good name,no?) are not going to market.
