how about an OCZ motherboard with "good" design?
Those are some interesting chips, although 4v its a little too rich for my blood.
You guys said that your going to put the tccd chips in the 3700EB... Well what is going to happen to the 3200 Platinum Rev2? As of now that seems to be your guys best memory. Will hte 3700EB get preference for better chips?
Is this with the fx55 I hope to buy off you?Originally Posted by OPPAINTER
RIP Dad. I will miss you always.
Q6600,DFI X48 T2R,280 GTX,4gig ReaperX,XiFi Prelude,LL TYR PC X-2000,Westinghouse 37,Klipsch 5.1 Ultra
I don't get it the EB does the same thing with volts don't they? And the new ZB DDR2 mem does 3-2-2-X also?
These memories need even more volts than EB to do 3-2-2 @ 270ish?
any updates ?
ASUS P5K-E // E8400 Q746A519
G.Skill F2-8000CL5D-4GBPQ
LC 550W GP// XPERTVISION 9600GT
nah not all PC3700EB did that once they find their individual stick max, no amount of voltage will get them higher regardless of loose timings or not... these volt loving new memory seem to do this better than 3700EB from what has been said aboveOriginally Posted by `schr0et
thats not what ive heard. ive heard all EB 3200 thru to 3700 scales fairly well with volts upto 3.2v. looser timmings also help until around 3-3-3-x.Originally Posted by eva2000
Specs
Asus 780i Striker II Formula
Intel E8400 Wolfdale @ 4050Mhz
2x2GB OCZ Platinum @ 1200Mhz 5-4-3-18
MSI 5850 1000Mhz/5000Mhz
Wester Digital Black 2TB
Antec Quatro 850W
Cooling
Swiftech Apogee
Swiftech MCP-600
HardwareLabes Black Ice Extreme 2
Audio Setup
X-fi w/AD8066, Clock mod, & polymer caps > PPAV2 > Grado SR60 & Grado SR325i & Beyerdynamic DT770 Pro & Beyerdynamic DT990 & AKG K701 & Denon D2000
no, not all. iirc even bigtoe said that eb stops scaling at a certain voltage and higher volts just wont help. and some sticks stop at lower volts wile others keep scaling.
Look to be another great OCZ product.
Problem is I have EL3200rev2 on the way,OCZ just has to slow down new product release,my wallet cant keep up...
BTW :ETA on these ?
Agreed my EB3500 did not even respond to voltage above 2.9v,3.0 yeilded no improvement.Originally Posted by saaya
Ryan,will these new chips be "certified" to run higher voltage and not void the warranty above 3.0v?
Asus P6T Deluxe, Core i7 920 @ 4.1ghz, Corsair Dominator Tri channel 1600Mhz
Evga GTX285, Raptor 150GB, Corsair HX620
Apogee GTZ, PA 120.3, CM Stacker STC-01, DDC 3.1 MCP355/XSPC top.
Win Vista Premium X64
It may be a good idea to let some of the gurus round these parts hav a beta test of the modules... if an independant review is done it will hold more water... no doubt this is already happening and I need to put my head back in the sand
Complete specs would be nice Ryan...
Max supported VDimm
FSB / Timings to expect
Chips used (if that can be disclosed)
I like it
VX/UTT Voltage Scaling, please contribute...
10x260 _ 1T-2-2-2-8-7-15 _ 3.3vDIMM _ 1.75vCORE
Mobile 3400+ CG 0437XDPW
DFI LanParty UT
XP120 w/ 120mm Thermaltake Thunderblade
2x512MB OCZ VX
BBATI 9800np w/Infineon
PC Power & Cooling 510w Deluxe
hmmm i dont think its hynix, i dont know any hynix memory that likes volts... but samsung! samsung memory loves volts! and it runs hot! maybe some older samsung memory? not tccd but another type... hmmm
il bet saaya's kidney it's Micron
DFI LanParty UT
2x512MB OCZ VX
probably.
Only winbond and micron have ever liked volts that I have seen. Samsung back in the TCB3 days... but thats it.
All along the watchtower the watchmen watch the eternal return.
Originally Posted by Rabbi_NZ
ok, ill take that and raise you saaya's left teste.
Specs
Antec Quatro 850W
Cooling
Swiftech Apogee
Swiftech MCP-600
Audio Setup
The Hynix chips on my OCZ PC4400 work well under 3.2-3.3v, but thats not exactly "extreme" BH5 voltage range. I have the exact IC model number in an email from Bigtoe, but Gmail is down.Originally Posted by saaya
Edit: They are Hynix BTD5 chips.
Less is more.
Its not Hynix...its not Micron...its not BH6 or BH5....you guys can guess all you want, we ain't tellin..LOL
We look for low latency, we found it with G die Micron but that ran out, we found a new source and this needs to be kept secret for a while.
Guys just respect we found something new and we are bringing it to the masses as cheap as we can.
Got a problem with your OCZ product....?
Have a look over here
Tony AKA BigToe
Tuning PC's for speed...Run whats fast, not what you think is fast
thats alot of volts. im glad i got EB when i did just after production restart.
these sticks also did 260 3-3-2-10 1T at 2.8vdimm. Good stuff, any chance of the -5bg chips mature'n into what the -5bc was able to do on a consistant basis? or are the g die microns gone also? havnt been keeping track.
I5 2500k@4.7ghz--Asus P8Z68-VGen3--4x4gb Gskill Ripsaw 1600 --EVGA GTX570--Crucial m4 128gb SSD--Corsair TX950w--Corsair H100--Corsair 800D
Scores are all 4+years old. updates soon.
All scores are outdated
24/7 3dmark06 6841
24/7 3dmark05 13357
24/7 3dmark03 22979
Very Mild 3dmark01se 55225
24/7 Aquamark 3 136020
big toe.. but i want to make my OWN memory modules! lol...
if its not micron and not hynx its samsung... but the best samsung chips are the tccd unless there is something we dont know yet...
I KNOW WHICH IS !!!!! :banana4:Originally Posted by bigtoe
ELIXIR/NANYA chip w000t LOL
infineon makes mems too... could be an infineon chip, no?
I used to have links here demonstrating how awesome I am, but it's been so long that they're not very relevant (and the pictures have disappeared), so I guess I'll have to get working on new stuff.
I might be interested in some of these if they can beat my Bh5.
I dont have any real problem pumping 4v through the ram as long as they dont die after a few weeks.
I think it's Mosel Vitelic RAM, but that's only a guess.I know those can do 2-3-2-11 at 200 MHz with low voltage, so perhaps they can do more but nobody tested yet.Originally Posted by µnrealneo²
i bet its some Lei chips!
Specs
Antec Quatro 850W
Cooling
Swiftech Apogee
Swiftech MCP-600
Audio Setup
so no matter who wins i lose my guts eh?
lol
ryan or tony, so whats the max volts it will be rated to run with officially? and will it need extra cooling?
Same question here, Saaya. I'd like to see how they'd run with 3.4v. I just upped my 3.3v line to 3.5v, so I've got some pretty decent voltage available.
Bedroom: D201GLY2, Celeron 220 (1.2ghz/512k cache); 1gb DDR2 PC-5300; Geforce 6200 PCI
Gaming: Core 2 Duo E4500@2.93ghz (266x11); Abit IP35-E; 3gb Crucial Ballistix PC5300@400mhz (4-4-4-15); XFX Geforce 8800GS@680/800 10123 3dmark06
HTPC: Athlon 64 X2 BE-2300 (1.9ghz); ECS mATX mb; 2gb Crucial PC5300; Radeon HD2600 Pro 256mb (DXVA HA in BD and HD-DVD)
Originally posted by Thunderbird1Ghz(Geforce4Ti4200) at Sharky Forums
And you arent gonna believe this, but that DVD rom will even read regular CD roms!!!!!!!
