+ Reply to Thread
Results 1 to 4 of 4
Thread: Abit Kg7-raid
    Xtreme Member Dapper's Avatar
    Oct 2002
    Central PA
    0
    Abit Kg7-raid
    Does anyone know if they are going to update the KG7 BIOS to use the bigger XP chips?
    I may want to get a 2400+ but if ABIT isn't gonna update the bios I'm not gonna risk the money on a new chip.
    I'll wait and get a new board and chip when Hammer series comes out.
    Xtreme Mentor
    Jun 2002
    PA, USA
    0
    I can't be certain, but I'd highly doubt they would. Even the KX7-333 doesn't _really_ support the newer chips.
    | 1.6GHz Intel E2140 @ 3.2GHz 24/7 | Abit IP35-E | 4GB Corsair XMS2 PC2-6400 | 512MB XFX Radeon HD4770 | 100% CPU OC & 24hr Prime95 stable | Heatware |
    XIP - can sit on his hair Marci's Avatar
    Jun 2002
    Wakefield, West Yorkshire, UK
    1
    Nah... they won't be doin that... all you'll be able to do is unlock the chip and run it on the lower multilpiers with a higher FSB.
    But even then you're not gettin the potential outta the chip....
    If you're gonna get one, do it right... the KG7 is a decrepid old board now anyways...
    Oct 2002
    Central PA
    0
    Well I have a KG7 now and I guess I'm gonna jump up to a KD7 Raid with the KT400 chip set and a 2400+ , My brother wants my KG7 Raid and 1800+ chip.
+ Reply to Thread
