+ Reply to Thread
Results 1 to 13 of 13
Thread: Troubles P4C800Deluxe(I875) fixed with TCCD mem.
    Xtreme Enthusiast Gamer's Avatar
    Jul 2002
    Belgium
    0
    got troubles using these modules (Gskill) with P4C800 Deluxe.
    betabios 1009d.001 fixed them.
    couldn't even boot @ 233x15, now I'm on 267x15 stable as hell
    biosupdates
    Dell XPS M1730 - X9000 @ 3400mhz-4096MB 667MHz DDR2 - M8800GTX SLI- 17"WUXGA+
    EVGA E762 4Way SLI Classified - 980X @ 6Ghz Ln² 6GB Dominator - MSI 5870 Lightning
    WWW.MADSHRIMPS.BE - Being Mad Doesn't Hertz You
    Jul 2002
    Belgium
    0
    non deluxe version and others can be found here
    Xtreme Enthusiast Malachia's Avatar
    Aug 2004
    Milan,Italy
    0
    i have some problems to go highter than 260mhz fsb in 1:1 whith every ram and bio 1016, now i try this one on my P4C800 DELUXE V2.00 and i will told you how it goes....see you later
    Administrator Jupiler's Avatar
    Jun 2002
    Belgium
    0
    How does this bios perform compared to the older ones?
    I have the P4C800-E, but spotted a beta bios on ASUS' site, dated 10/14/04. Still using bios 1014 now.
    Rig #1
    Gigabyte P67A-UD4 trying to figure out this POS board
    2600k @ ?????
    2x2Gb GSkill RipJaws-X 1333 (7-7-7-21)
    ATI 5850
    Coba Nitrox 750W
    Watercooled with HK 3.0 CU, Watercool GPU-X³ 5870 Nickel, PA120.3, Laing Ultra with XSPC top
    Rig #2
    DFI UT P35-T2R (0317 bios)
    E8200 @ 4000 (1.216V) / 4100 (1.248V) / 4200 (1.296V) / 4300 (1.344V)
    2x2Gb Chaintech Apogee GT PC2-8500
    Powercolor 4870
    Corsair 520HX
    Watercooled with HK 3.0 CU, EK-FC4870, Feser tripple, Laing Ultra pump
    Quote Originally Posted by Movieman View Post
    I've got Supermicro boards that lasted longer than one of my marriages!
    Jul 2002
    Belgium
    0
    good I must say.
    always used the 1016 for over a year.
    no performance loss, PAT enabled, 2.65vdimm, vcore is more stable then before, same results with Sisoft, benchmarks,..... (not noticeable).
    had some A64 setups, only I can't bare it to sell this setup, bought it in May last year.
    still going strong with my same old PIV3.0C (my best was 2 months with one setup :p).
    Banned Onepagebook's Avatar
    Jan 2004
    Land of Buckeye
    0
    why no one is aware this ?
    Some said "I think Gxxxxx TCCD sucks with 875 chipset"
    Well...What can I say?
    Apr 2004
    Hong Kong
    0
    I am doing dual channel 267fsb 2.5-3-3-8 2.75v p4c800d pcb 1.02. Ther are ADATA566 512mb new red pcb a pair of TCCD 434 & other pair of TCCD 431, all memtest extend test stable. Using both bios 1017 & 1019.01 didn't experience any problem.
    Apr 2004
    Hong Kong
    0
    Quote Originally Posted by Onepagebook
    Maybe TCCD's are suck at CL3 with i875p at high fsb, they don't like CL3, all get errors in memtest#5.
    I tested with both ASUS P4C800D & Epox 4PCA3+, using 8 sticks 512mb TCCD one at a time, all CL3-4-4-8 DDR566 got errors in memtest#5 or #8.
    But they love CL2.5-4-4-8 , so is 875p don't like CL3 at high fsb ?
    Xtreme Infrastructure Eng Gogeta's Avatar
    Feb 2004
    2
    I just finished testing my 1GB kit of GSkill PC4400 2.5-3-3-7 with the 808 PCB. I'm using a P4C800-E Deluxe rev.2 with the 1017 BIOS. The 2.4c is cooled by the a lapped stock Intel heatsink in a 19c ambient room. I know its not cpu limited because I was running SuperPi 1M's at 300MHz 5:4 with OCZ PC4400.
    275MHz is a no-go at 2.5-3-3-7, but runs stable enough for a Sandra mem bench and Photoshop editing at 2.5-4-3-7. Vdimm is 2.75v...2.85v did not help.
    Setting the timings to 3-4-4-8 only gained about 5MHz. I really hope a BIOS update corrects this problem.
    BTW - Why are the cpu-z checksums different?
    Less is more.
    Apr 2004
    Hong Kong
    0
    I don't know it is a bios problem or else. But I would think the difference btw 1017 & 1019 will be the CPU lock free function.
    I can go 275fsb cl2.5-3-3-8 but not stable to complete benchmarks
    We might need high quality i875p or better cooling for the north bridge running 1:1 at such timing. Remember that 1/2 of your Vdimm will be the VTT of the north bridge. So higher voltage will heat up more the nb too. For my CPU, it shouldn't be a problem cause mine's 2.4c were tested prime95 48hrs ok at 3.4g default voltage
    Is there anyone water cool the nb or with a new bios, and get better result ?
    Feb 2004
    2
    Its definitely not NB cooling...its just the weird reaction TCCD has with the 875P chipset. I'm pretty fed up with this setup...itchin' for an A64.
    Less is more.
    Apr 2004
    Hong Kong
    0
    Unfortunately, my abit Av8 didn't good enough to do 275fsb cl2.5-3-3-8 due to acp/pci lock problem. I can't test the limit & quality of my tccds.
    Waiting for nforce4.....
    Just 271fsb on i875....
    Xtreme Member jagare's Avatar
    Sep 2003
    Corona, CA
    0
    Yeah me too, best I can get with my PQI TCCD stable is 275MHz with 2.5-4-3-7 timings. It looks like the TCCD chips run quite a bit better on a AMD setup. Now I'm itchin for a 3200+ s939 + MSI Neo2 Plat.
+ Reply to Thread
