+ Reply to Thread
Results 1 to 18 of 18
Thread: MSI K8n neo2 + 3000 (what COOLER?!)
    Xtreme Enthusiast The Runner's Avatar
    Aug 2003
    England, UK.
    0
    bought the chip OEM w/ the mobo, arriving next tuesday.
    So wondering what cooler I should get for it
    Thermaltake XP-90? (i think) looks pretty decent, but is a bit overpriced compared to the bigger version, but I dont think that works with my mobo :E
    When buying a cheap cooler, what do I need to look for? Cause none of them say socket 939, just socket 940.
    Well I can get the SLK-948-U for £19 - edit, dang they're not in stock either!
    the XP-90 is on there as well for £22, but unconfirmed shippment for 2nd Nov.
    Xtreme Addict hollywood's Avatar
    Jan 2003
    Littleton, Colorado
    3
    Quote Originally Posted by The Runner
    I use the MSI K8N Neo2 Platinum and the Thermalright XP90. They fit together perfectly! Plus your memory is cooled by being right under 1/2 of the heatsink. There is a TON of clearance on all sides and the memory can still be added or removed from ANY slot when it's installed.
    I simply love the XP90...get it.
    Great temps w-AS5 as well. Only 42C full load @ 2600MHz, 36C idle.
    Heatware
    Main
    intel i5 3570k @ 4+ GHz | Gigabyte Z77X-UD5H Rev 1.1 |Crucial Ballistix Tactical VLP 2x8GB DDR3-1600
    intel 335 240GB SSD | WD Black 640GB HDD
    Sapphire AMD 7870XT 2GB w-Boost (Tahiti LE)
    Creative X-Fi Titanium PCI-e
    HTPC
    AMD FX 6300 Vishera | ASRock 970 Extreme 3 | Kingston HyperX Black 2x4GB DDR3-1600
    intel 320 120GB SSD | Seagate Barracuda 640GB HDD
    AMD Visiontek HD7850 2GB
    Dlink DWA-556 Wireless N Adapter
    Tablet
    Lenovo IdeaTab A2109 - Running rooted J-Bean & ADW
    Aug 2003
    England, UK.
    0
    nice! I'm thinking of getting one :o
    Jan 2003
    Littleton, Colorado
    3
    Recheck my post...I added some info.
    Heatware
    Main
    HTPC
    Tablet
    Aug 2003
    England, UK.
    0
    So you would say its worth an extra £15 over the SLK-948-U ?
    Aug 2003
    England, UK.
    0
    just a small update, went for the XP-90 in teh end, yeah it was £15 dearer, but I read up that its so much easier to install, and I am changing cpus alot, I hate fiddling around with coolers!
    I'll report my overclocks sometime next week
    Xtreme Enthusiast CTKP's Avatar
    May 2004
    East Bay, California
    0
    Yeah, the XP90 was a good choice. The only bad thing i can think of is the pressure you have to put on the chip to get the hooks in the retention clip.
    Aug 2003
    England, UK.
    0
    Quote Originally Posted by CTKP
    eek that sounds a bit fiddly
    I guess if I press down in a leveled out force, it wouldn't do it any harm
    Xtreme X.I.P.
    Aug 2002
    0
    I use a Zalman copper 7000 series. It is a doddle to fit on and works fine.
    Regards
    Andy
    Xtreme Enthusiast Shade00's Avatar
    Dec 2003
    Louisiana
    0
    It is a bit tricky to get on there, but it's well worth it. It's a fantastic HSF.
    Bedroom: D201GLY2, Celeron 220 (1.2ghz/512k cache); 1gb DDR2 PC-5300; Geforce 6200 PCI
    Gaming: Core 2 Duo E4500@2.93ghz (266x11); Abit IP35-E; 3gb Crucial Ballistix PC5300@400mhz (4-4-4-15); XFX Geforce 8800GS@680/800 10123 3dmark06
    HTPC: Athlon 64 X2 BE-2300 (1.9ghz); ECS mATX mb; 2gb Crucial PC5300; Radeon HD2600 Pro 256mb (DXVA HA in BD and HD-DVD)
    Originally posted by Thunderbird1Ghz(Geforce4Ti4200) at Sharky Forums
    And you arent gonna believe this, but that DVD rom will even read regular CD roms!!!!!!!
    Xtreme Member seb87's Avatar
    Aug 2004
    Italy ( Trento )
    0
    zalman a7000b - cu
    Xtreme Addict GazC's Avatar
    Jan 2004
    UK
    0
    I'd like to know if the XP-120 fits. Now that the .90 AMDs are out I'm looking at this mobo and possibly a 3400.
    £58.73 - This is the amount of money a loyal customer is worth to Overclockers.co.uk
    Beware of buying from overclockers.co.uk, they will swindle you by abusing the consumer law if they need to refund you for faulty hardware. Thieving gits
    May 2004
    0
    Xp-120 hits some caps on the board.
    MSI
    K8T Neo-FIS2R Okay
    K8TM-IL Okay
    K8T Neo2-F Okay
    K8T Neo2-FIR Okay
    K8N Neo-FSR Okay
    K8N Neo Platinum Okay
    K8N Neo2 Platinum Not Compatible (caps mechanically obstruct pipe.)
    Xtreme Member PnoT's Avatar
    Oct 2002
    Las Vegas aka Sin City!
    0
    I'm currently running a ThermalRight SLK-948U for now and it's a good hs. I also have a panflow 92mm on it and it's dead quiet putting out close to 60cfm. The xp-90 is a very good hs as well i'd get that for sure if your debating. Here's a pretty good guide on a few of the newer hsf combos out there for each socket: http://www.overclockers.com/articles373/
    It says the database is not updated but every new hsf combo that comes in they add it to the list anyway
    E8400 @ 4ghz 24/7
    DFI LP LT X48-T2R
    G.Skill F2-8500CL5D-4GBPK
    BFG 9800GX2
    2 x 150GB Raptor X in RAID 0
    Aug 2003
    England, UK.
    0
    Ok guys, I'm sufficiently impressed by my purchase now. Should be coming tomorrow with board and chip on tuesday. Should have it up and running nicely by Friday. Will report back then
    edit: btw how much as5 should I put on the chip? Small blob in the middle like intel procs?
    XS D2OL & RAM News jjcom's Avatar
    Aug 2004
    Somewhere, USA
    0
    yep sounds about right...maybe a bit more since these Athlon 64 cores are...big. I hate having to put presure on my heatsink...mainly since I'm using an Athlon XP. The POLO HS I've got is incredibly hard to install. I almost sent my scewdriver through the motherboard
    Aug 2003
    England, UK.
    0
    quick reply needed, i am looking at the guide, i need to drip nail varnish remover onto the mobo to remove the old RM?
    Im unsure of if I should do this, and if so could do with a better guide.
    Can't find one anywhere
  18. #18
    Aug 2003
    England, UK.
    0
    nvm done dat, wasnt even glued down.
    The board layout is great, however I'm far too tired to install it now. Will install tomorrow morning!
    Fingers crossed I aint got a duff board.
    Either dat or a duff chip, there was some condensation on the IHS! Cause it arrived on an extremely cold day. However there was no damp.
+ Reply to Thread
