What so u think is gonna be better under Zalman 7000AlCu? The 3.4C is not going higher now, when its gonna be colder it ll go on max 3.74Ghz .
E5200
Asus P5Q-VM
A-DATA 2x2GB
Zotac 8800GT
500W Seasonic
Originally Posted by trakslacker
what??? are you sure? what are your temps? whats the highest vcore you tried? are you sure the memory and mobo are ok?
I tried 3 different memory no from them made more than 217Mhz in 1:1 realy stable, like after a few hours of memtest errors , but even with dividors nothing when I go above 217Mhz it usualy reboots after a few hours of Prime or whatever, it's stable but than it just restarts , my +12V line is like 12.40-12.50 idle & 12.00-12.10 under load, I dont think it's the mobo it's just >220 FSB. I ve got 32-34C IDLE & not more than 50C under load.
E5200
Asus P5Q-VM
A-DATA 2x2GB
Zotac 8800GT
500W Seasonic
hmmm is that with the cou fan at full speed?
what mainboard?
y. the fan is @2700-2800rpm . The mobo is P4P800 DLX
E5200
Asus P5Q-VM
A-DATA 2x2GB
Zotac 8800GT
500W Seasonic
Do u think it can be my PSU coze it's just Chieftec 360W with +12V 17A & tweaked +12V rail from 11.46V=>12.10V@load?
E5200
Asus P5Q-VM
A-DATA 2x2GB
Zotac 8800GT
500W Seasonic
So it looks like it was the PSU after writing the post it turned off & it took the mobo also , my mobo is back from rma & the PSU still not, I think I ll try Fortron 350W.
E5200
Asus P5Q-VM
A-DATA 2x2GB
Zotac 8800GT
500W Seasonic
