+ Reply to Thread
Results 1 to 2 of 2
Thread: 875 Mobo Question ?
    Xtreme Member aNabolic's Avatar
    Dec 2002
    Kent, UK
    0
    875 Mobo Question ?
    Hi,
    This has been asked before but im stuck. Currently running a (250FSB)3.4EE@4.2 on a Rev 1.0 Abit IC7 Max 2, with 1GB OCZ 4200 EL.
    Its OK but sometimes unstable, I was thinking of changing the mobo.Just dont know what to. There is the MAX-3 and DFI Pro875.
    Im using the OCZ booster to ramp up to 3v above the 2.8 on the max2, but the vtt is limiting me.
    Im using a Vapo LS and just wondered what MOBO would actually give me better clockability and stability, ive had my max-2 for nearly 2 years now.
    Cheers all,
    Brett
    Xtreme Member CrunchTime's Avatar
    Mar 2004
    0
    im positive that the new MB probably wont do much, might even hurt your OC. you've probably hit the max of your chip with that cooling
+ Reply to Thread
