Anyone has seen a comparation between the HP´s processor Alpha and Opteron or P4 ?????
It is faster ????
It is faster ????
Depends on what you do. It requires special code to make use of the capacity. I'd go with a itanium cluster ahead of it if i wanted a supercomp
Opteron 165
Dfi NF4 Expert
4x1 1GB twinmos PC 3200
XFX 7900GT 550/1500
I'd probly go a Opterons cluster for the most combatilbity.
i thought they canned the alpha
6.6k in 2k3 with under 500 invested, can ya beat that?
nope, HP annouced the 2.1ghz Alpha. Its going to be the last of the proud and mightly Alpha line...
jjcom
The EV8 bus system was the inspiration for the orginal athlon cpu bus.
OCZ employee and proud of it.
If you have actually personaly experienced a problem with a OCZ product that was not solved quickly by our wonderful support staff I would like to know. Feel free to PM
I am overclocked!
"Posted on Mar 30, 2005 at 1:35 AM by StormGod
In soviet Russia memory overvolts you! "
nice to know but there processin is somthing that you cant compare to a pc they work totaly differntly i mean like that mac runs RISK so it does not need as much processing power because it work on a differnet level
ryanpgroovy
K7 CPUs use EV6 bus.
i5 750 4.20GHz @ NH-D14 | 8GB | P7P55DLE | 8800U | Indilinx SSD + Samsung F3 | HAF922 + CM750W
Past: Q6600 @ 3.60 E6400 @ 3.60 | E6300 @ 3.40 | O165 @ 2.90 | X2 4400+ @ 2.80 | X2 3800+ @ 2.70 | VE 3200+ @ 2.80 | WI 3200+ @ 2.75 | WI 3000+ no IHS @ 2.72 | TBB 1700+ @ 2.60 | XP-M 2500+ @ 2.63 | NC 2800+ @ 2.40 | AB 1.60GHz @ 2.60Originally Posted by CompGeek
your right , My bad
I am overclocked!
