I want replace my 1.8A with 2.66 C1.
A little question : is it possible to run it at 3.3-3.4 ghz with watercooling only ?
Plz post your oc result with this chip (including voltage and cooling).
Thanks![]()
Thanks![]()
What was the highest you were able to push your 1.8a with just WC? Just purchased me a 1.8a to tinker around with on an abit it7 max2 and out of the box i'm stable at 2.8 with stock air on it. WC/Pelt should be here wed this week so i'm anxious to see what i can crank her up to. I've seen quite a few other posts of ppl doing 2.6-2.8 with air so these little guys are cranking. I'd like to find a good article on tweaking out the it7max2 but so far no luck.
On a side not two friends purchased a couple of p4 2.5's and one is doing 2.9 on air with stock hsf and the other can only manage 3.1 (prime stable) and 3.3 (unstable prime) with a wc/226wpelt rig. He even volt mod'd the 2.5 with no luck in achieving a higher clock. It's also one of the new C1 steppings. I believe he's got the worst luck i've ever seen heh
http://www.geocities.com/henry_moniaga/3100.txt (not stable, can't do 3dm2k1), 2.9ghz (1.7v) for 24/7 use, 3.05ghz (1.8v) for benching.Originally posted by PnoT
Anyone with 2.66 ??
Thanks !!
If you are lucky, one of the newer batches of 1.8A might do 3ghz on watercooling. Mine does that on air but requires just a little bit too much voltage for me to be comfortable on air cooling so I run it at 2.9ghz 24/7.
Seems like all of these 1.8A cpus (mine is SL63X pack dated 23/7/02) are doing 2.7ghz minimum. Definitely the best value cpu available at the moment, especially when you consider the sort of fsb you are running at this sort of overclock.
The C1 steppers seem to be a mixed bunch - most will do 3ghz, but anything over that requires a bit of luck in what cpu you get. I would wait until the stepping matures a bit and filters through the supply chain, by that time (about Christmas) you should be able to buy 1.8ghz C1 steppers that have a good chance of doing 3ghz+ easily. Certainly that would be the only cpu that could tempt me away from this 1.8A I've got at the moment. (unless Intel pull out a 3ghz cpu that will do 3.8ghz:p)
Hi Henry you should be ok with water at 3.3/3.4g mine will run that speed at default volts in the prommieOriginally posted by Henry
Thanks![]()
Thanks toofast![]()
What's your stepping?
My chip (SL6DX) runs 3ghz at default vcore and 3.36 stable at 1.75V on my water setup. Just waiting for my prommie now.
Toofast - How high can you run at w/ your prommie setup?
Running 3409 @ 170/226 using 3:4 . 1.66 vcore(or lower, thanks to a erratic, fluctuating Abit) I've got a Malaysia SL6DX with a pack date of 08/28/02. Straight H20, Eheim 1250, DD Maze3, heater core.
Hi m8 it will do 3dmark @ 3500 and sis screenies @ 3600 max volts i use is 1.7v anymore just produces heatOriginally posted by ronnie0738
Toofast - How high can you run at w/ your prommie setup?![]()
Thanks for the info. On my water chilled system, I was able to 3DMK at 3400 at 1.8V and sandra at ~3420 at 20C cpu temp.
Henry,
My 2.66 on an IT7 MAX runs stable at 3.2 on air....prometeia is already on it's way here....will post differences after install.
I am not sure how much faster I can go with the prom, but soon we will know the difference a prom cam make![]()
New rig:
939 neo 2 platinum
FX-55@ 271 x12... 24/7
Prom 1
Gskill 2x512...
1 gb 3700EB for sale....any reasonable offer
OCZ ram booster....for sale as well
Sapphire X800XT VIVO
Twin Raptors
PCI raid card
OCZ 520 PSU
What hsf & vcore are you running mike?
Using a Sunflower with intel fan....not that terrific.Originally posted by ronnie0738
Can't complain much....a 540 mhz overclock on air.
core voltage 1.6v
New rig:
939 neo 2 platinum
Prom 1
Gskill 2x512...
Twin Raptors
PCI raid card
OCZ 520 PSU
I hope to get one when the prices drop. Want to hit 3GHz![]()
2.66 benched at 3210 @ 1.58volts load.....See sig for 3dmark compare...but this baby wouldnt even prime for more than 2 minutes above 3gig....
Any higher volts would not make a difference at all, even above 1.85 set in bios would make system unstable whereas backing down to 1.625 in bios was fine....wierd....
Anyways wouldnt even post at 3.3 and this was with water and air....
Ive gone back to a nice 2.4B that i bought and she gets into windows at 3160 and primes at 3100 for about 15 mins before crashing...3gig is 100% stable though @ 1.65volts. Again more volts doesnt mean better results with this chip either....
Im selling the 2.66 and and going to whack this 2.4 into the vapo when she arrives.....dunno when that is though yet, cos im still saving for it![]()
Intel P4 3.2 EE || Asus P4C800-E || Prometia Mach II || 2 x 256Meg HyperX 3500 || Antec TrueControl|| Sapphire Radeon 9800XT || 2x Raptors || Samsung 172T
OCAU 3DMark Team || 3DMark Compare: 26847 || World of Britney|| PCDB Entry
"Sundance is weird. The movies are weird. You actually have to think about them when you watch them. " -Britney Spears
I am at 3.91Ghz 169FSB 24/7 but I use chilled water.
3.2Ghz is realistic, with just water
ASUS Maximus Gene V
ASUS GTX 680
Intel 3770K Overclocked
Intel RTS2011LC Cooler
Corsair Dominator GTX 2
Corsair Force GT RAID 0
Corsair AX750
Intel I7 3960X
Asus Rampage IV Extreme
Asus 580 Matrix SLI
Corsair Dominator GTX 8GB
Antec 1200W PSU
Dimas Benchtable
3.91Ghz wow nice chip :pOriginally posted by FUGGER
damn...3.91, nice oc! :thumbsup:
You got any sandra benchmarks?
3.91 ghz !!!!Originally posted by FUGGER
3.2Ghz is realistic, with just water![]()
Nice OC there![]()
is that chip unlocked? at 169 with a 2.66, that would only be 3380 mhz.....
Err, typo 3.391Ghz
ASUS Maximus Gene V
ASUS GTX 680
Corsair AX750
Intel I7 3960X
Asus 580 Matrix SLI
Antec 1200W PSU
Dimas Benchtable
Lmao well done guy`s for playing along![]()
OC 1000 Mhz
The ram can go higher on my Pommy with 2.66 than the 2.8
Best OC regards
Tom Holck
Very nice! :thumbsup:
Wow! thats amazing. I think I need a prometeia![]()
If my answers frighten you, stop asking such scary questions...
- Hush
- Intel i7 3770 • XSPC Raystorm • Gigabyte G1.Sniper M3 • Crucial Ballistix DDR3-1600 • 9-9-9-24
- Gigabyte Geforce GTX 670 OC Windforce • XSPC Razor GTX680 Rev.2 modified
- Mushkin Chronos Deluxe 240GB SSD • Intel 520 Series 240GB • WD Black 1TB 64MB Cache
- Custom Water Cooled Fractal Designs Define R4• Antec HCP-1000 Platinum
- EK Coolstream XTC 280 • Cougar CF-V14HB Vortex HDB • XSPC EX240 • Scythe GT AP-15
- Dazmode Storm DDC 3.25 • XSPC Acrylic Tank Reservoir
