+ Reply to Thread
Results 1 to 17 of 17
Thread: 400W ATX troubles and a pelt?
    Aug 2002
    0
    400w ATX PSU troubles ...
    SO I found thisPowmax PSU with 12V 25A . I figure for $30 its worth a try for my 226W Pelt.
    I cut the Molex off a 12V from the PSU , soldered it to my leads from the Pelt , and heatshrinked the connections.
    Just one problem.
    When I turn the rocker switch on - on the back of the PSU , nothing happens. The PSUs fan doesnt start. Nothing.
    I was hoping this might work , grrr. There is nothing else connnected to this PSU. Any advise?
    2600XP-M @ 2500 mhz
    1024 OCZ PC4200 2,3,2,11
    9800 NP / XT
    450 / 340 Mhz
    NF7-S rev2
    36G Raptor
    Antec TruePower 430 Modded
    Overclocking Guru OPPAINTER's Avatar
    May 2002
    SoCal, USA
    0
    You have to ground 2 of the pins on the PSU, I forgot the numbers I'll be back in a second.
    OPP
    Xtreme Member CCC's Avatar
    Oct 2002
    Iowa
    0
    its pin 4 and pin 6
    Win7 64 Ultimate
    i7 930 - 4200mhz 24/7 - Dtek v2
    ASUS P6X58D-E
    2 x MSI 6970's xfire
    3 x 2gb G-Skill 2000mhz
    Samsung 27" LCD
    SilverStone ZM1200w psu
    2 x 300gb WD Velociraptors Raid 0, 4TB storage
    PS3-used mostly for bluray and media server
    May 2002
    SoCal, USA
    0
    I believe the wires are 17 Green 16 Ground. This will make the PSU be turned on all the time and you woun't need it hooked to a mobo. It's the 2 in the picture, I just use a paper clip as a Jumper.
    OPP
    Xtreme Addict majormav's Avatar
    Jun 2002
    england
    0
    i always use 4 and 6 yo power pelts you got 4 and 5 there opp
    May 2002
    SoCal, USA
    0
    Whats the difference in 5 and 6??
    OPP
    Jun 2002
    england
    0
    dunno .... was just pointing out the ones i use .... and was going to post a pic but you beat me to it so pointed out the pin numbers off your pic
    May 2002
    SoCal, USA
    0
    I believe they are both the same, basic ground wires.
    OPP
    May 2002
    SoCal, USA
    0
    I was right 17/16 O yea, OPP and his bionic memory
    Aug 2002
    0
    Let me try that , Ill post back. Thanks btw!
    2600XP-M @ 2500 mhz
    9800 NP / XT
    450 / 340 Mhz
    NF7-S rev2
    36G Raptor
    Aug 2002
    0
    I tried the paperclip in 16/17. NO GO. grrrr
    Looking at the color of the wires into the ATX plug:
    14- green
    15 -black
    16 -black
    17 black
    Any suggestions?
    2600XP-M @ 2500 mhz
    9800 NP / XT
    450 / 340 Mhz
    NF7-S rev2
    36G Raptor
    May 2002
    SoCal, USA
    0
    14/15
    Your counting wrong the green is actually 17.
    OPP
    Xtreme Relic TheDude's Avatar
    Jun 2002
    Hilton Head, S.C.
    0
    Can't you use 4 and 6? I do.
    I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me.
    Hunter S. Thompson (1939 - 2005)
    Aug 2002
    0
    GOT IT!
    Duh... easy!
    Thanks again!!
    2600XP-M @ 2500 mhz
    9800 NP / XT
    450 / 340 Mhz
    NF7-S rev2
    36G Raptor
    May 2002
    SoCal, USA
    0
    4 and 6 are ground
    OPP
    Jun 2002
    Hilton Head, S.C.
    0
    Originally posted by OPPAINTER
    4 and 6 are ground
    OPP
    DUH sorry I see now..I was coming over 6 from left on notched side and then 4 from right. which is really 16 and 17..damn painkillers for my back are making me tarded!
    May 2002
    SoCal, USA
    0
    Dude,
    Please stay off of the Pills my man
    OPP
+ Reply to Thread
