Anyone has an ideia on what temperatures should I have with MCW50T + 80Watt TEC with the radiator EVO120? (the WC setup is only for the X800PRO). Ambient temperature is arround 28ºC-30ºC.
Ati temp probe gives me like 2°c idle (1.75v and 610core 16pipes enabled) but gets to 40-50°c under heavy load. The 80w pelt isn't powerful enough to keep it cool. But it still beats normal h2o I guess.
A64 3200+ Newcastle @ 2900mhz MachII Chilled | Dfi Lanparty UT 250GB | 160GB Maxtor | 74GBWD Raptor | 512MB BH-5 @240 2-2-2-11 | x800pro VIVO@16pipes 610/600 80w pelt cooled
30k 3dmark2k1
your rad is probably not powerfull enough. the hotter the water the more effiecient works a radiator. good rads can dissipate heat even when the water temp is only slightly above ambient...
or its the fans... what fans are you using?
hmmm could be... but i think if tecs die they just stop working.
what are your water temps?
if adding another rad makes the temps worse maybe the pump is too weak?
2 rads are pretty restrictive...
the difference between one rad and two rads without a pelt is of course going to be much lower :P
without the pelt you have less than half the heat the loop has to handle
and yes, your pump is VERY weak. it has a theoretical max of 300L/hour ,the average people have and wich works out best is 1000-1200L/hour
Man I get way lower temps
At stock volts, I got -21 deg C idle IIRC (havent run stock volts in quite a while )
At 1.8V I get h2o temp - 13 deg C idle, and h2o temp + 22 deg C full load. Obviously 1.80V is too much for that little 80 watter , really need a 172W pelt for the higher voltages.
X800Pro class 3DMark01 : 36670
X800Pro class 3DMark03 : 16092
Ti4200 class 3Dmark01 No 1 : 22213
Super Pi 1M : S754 28 sec, FX53 25 sec
HEXUS Pifast : S754/Prom 40.55sec, FX53 36.92sec
Author of A64 Tweaker
Co-author of NF2 Tweaker
