+ Reply to Thread
Results 1 to 7 of 7
Thread: Fx53 S939
    Xtreme Member morbidj's Avatar
    May 2004
    The dogg pound, Denver CO
    0
    Fx53 S939
    I have an opportunity to pick up a 1 week old FX53 what do you think is a fair price for the chip it is a retail? The owner is having major issues with his mems and decides to just stick it out with P4EE.
    XS D2OL & RAM News jjcom's Avatar
    Aug 2004
    Somewhere, USA
    0
    so its used....retail would normally be alittle below $900 so I would say see if he/she will go for $600. that would be about 30% off. sounds about right....
    Xtreme Addict Arkangyl's Avatar
    Jan 2004
    somewhere in Massachusetts
    0
    er, how much might you be able to buy it for? $840ish new so yea, $600 or less is a good price
    CPU:: i5 750
    GPU:: GTX260-216
    MB:: EVGA p55 SLI
    RAM:: 4gb DDR3-1600
    AUDIO:: Xonar Essence STX
    May 2004
    0
    Ok thank you for your input guys. Ill see if he will take 600 for it.
    Xtreme 3DMark Addict Geforce4ti4200's Avatar
    Sep 2003
    0
    dont think he will sell this cheap, those go for 900 new, I say 800 used
    3000+ Venice 240x9=2.16GHz(ondie controller limit) 2x512mb patriot tccd ram
    9700pro at 325/310 runs all games buttery smooth!
    9700(8 pipe softmod, 128m) at 410/325 23821 at 325/310 21287 at 275/270 19159
    9500(4 pipes, 128m) at 420/330 18454 at 275/270 13319
    9500(8 pipe softmod, 64m) at 390/310 19201 at 275/270 16052
    9500(4 pipes, 64m) at 400/310 16215 at 275/270 12560
    3dmark scores with Ti4200 and Ti4800se
    Ti4200 at 340/730 19558 at 300/650 18032 at 275/550 16494 at 250/500 15295
    3dmark scores with older gpus
    Ti500 at 275/620 14588 Ti200 at 260/540 13557 MX440 at 380/680 11551
    Xtreme Gamer Reflex1's Avatar
    Jan 2004
    Europe
    0
    1 week isn't exactly old ...if he has the invoice and warrenty etc still ... 700 wud be good.
    Intel i7 930 @ 4.2Ghz 24/7
    Asus Rampage 3 Extreme
    Asus Radeon HD 6990
    Corsair Dominator GT 6GB
    Corsair AX1200, 600T
    Intel X25-M 160GB
    Dell U3011 30" Monitor
    Xtreme Addict JNav89GT's Avatar
    Oct 2002
    IL
    0
    given limited supply now $700-800 is fair
    it's never fast enough!
+ Reply to Thread
