+ Reply to Thread
Results 1 to 11 of 11
Thread: Prometeia mach II@r404 + dry ice…
    Registered User Dj Rudy's Avatar
    Jul 2004
    Italy
    0
    I and my friend leghorn have had this strange idea.... We had dry ice in abundance and therefore we have decided to cool is mb that the chipset.....
    with mine 2,8 nw: 2.8@4200 1,6 v prometeia without dry ice full load - 37° C
    2.8@4200 2,05 v prometeia with dry ice full load - 38° C
    2.8@4510 2,05 v prometeia without dry ice s-pi 1mb blocked to 4° loop
    2.8@4510 the 2,05 v prometeia with dry ice s-pi 1 mb: ok but do not have the screen why ended s-pi the system it is blocked....
    images.....
    excused for my ugly English
    Bandwidth Freak kakaroto's Avatar
    Dec 2003
    0
    nice project
    But with only Dry Ice you achieve better results
    Jul 2004
    Italy
    0
    i know but it was only in order to try the dry ice within little days the tube for the dry ice arrives.....
    k|ngp|n/Sham my brothers hipro5's Avatar
    Aug 2002
    Athens---Hellas
    0
    Good .... but why don't you try one Delta fan 12 x 12 cm 190 cfm on the back of the Prometeia's condenser and one on the front of it(push - pull - 190cfm too).........I think you'll be amazed........
    INTEL PWA FOR EVER
    Dr. Who my arss...
    Xtreme Guru freecableguy's Avatar
    Jun 2003
    Santa Clara, CA
    0
    Yes, yes. Hit it with the big guns. Nothing like screamer fans to amaze you.
    Intel Core i7-2600K ES (D1) @ 5.0GHz - 1.38v | ASUS Maximus IV Extreme ES
    4GB (2x2GB) Corsair DDR3-2133, 8-10-8-27 - 1.65v
    ASUS 480GTX SLI | Dell 2404FWP 24" flat-panel widescreen LCD
    Onboard Realtek sound | Logitech Z-5500 5.1 digital surround speakers
    2x WD 74GB Raptor HDDs (RAID 0) | Plextor PA-755A DVD-/+RW
    Corsair HX1000W PSU | Custom watercooled Lian-Li PC-G70B
    Jul 2004
    Italy
    0
    Wink
    there are the delta,... the frontal 12x12 has been removed to put the dry ice and the posterior delta is installed in aspiration....
    Aug 2004
    Torino-Italy
    0
    stardi... ma guarda chi si incontra da ste parti
    interessante dryice+prommy
    P4 550 3.4@4.311 2*256 mushkin pc3200@270 pov fx5900xt 2*37 gb raptor raid 0 toshiba sdm-1812 fortron 400w 30" s.pi 1M
    Xtreme Addict HawainPanda's Avatar
    May 2004
    Tucson, Arizona
    0
    neat!, do the images not load up nymore..i can't see them
    Xtreme Enthusiast boshi's Avatar
    Apr 2004
    Berkeley, CA
    0
    redex
    Xtreme Enthusiast Cow2kie's Avatar
    Feb 2004
    USA, SC
    0
    i took off the front panel of the prommy and i get like 5 degrees better temp. It helps me none for the oc though since i cant put more than 2v through this chip
    Pc Power and Cooling SILENCER® 750W
    Q6600 (kentsfield) @ 3870
    asus p5k-e
    Gskill 800 @ 1032
    bfg 8800gt
    Creative SB XFI plat
    Xtreme Member vkbms's Avatar
    Aug 2004
    Pistoia - ITALY
    0
    abitiamo a meno di 100 km e vedi chi trovo qui.....
    cmq complimenti
    SORRY 4 THE ENGLISH
+ Reply to Thread
