OCN2
Results 1 to 9 of 9
Thread: OCZ Platinum PC3700EB in K7 System
    Oct 2003
    Massachusetts, USA
    I've decided to try some PC3700EB in my mobile 2600+ system, I was just wondering what should I expect out of this stuff...? I've seen some crazy OC's from it in K8 and P4 systems.
    Anyway, I wanted to try it in a K7 system.
    Thanks for any input.
    AMD XP-M 2600+ @ 2.4GHz (12x200) - 1.75v
    DFI NFII Ultra Infinity Rev. A
    2x1GB Crucial Ballistix Tracer PC4000 @ 400MHz 2-2-2-5 - 2.8v
    BFG 7800GS @ 475/1550
    OCZ Powerstream 600W (+3.6, +5.4, +12.6)
    Swiftech MCX462-V-->92mm Tornado-->MCX159-A
    nForce UDP 5.10
    Forceware 97.44 XtremeG
    Win XP Home SP2
    Jul 2003
    The Netherlands
    It won't perfom the same on a k7 as on the k8 or intel. A64 isn't as depending on cas latencies as the k7 is.
    Probally you're better off with bh5's...
    Oct 2003
    Massachusetts, USA
    well I seem to have 240FSB right now ok. 2.9vdimm, 3-3-2-11 (stock).
    Anybody got any tips for this memory in a DFI Infinity? Like for those other timings (e.g. Act to Act, etc..) or if CPC should be on or off. They are the 2x256 kit.
    nForce UDP 5.10
    Win XP Home SP2
    Tyler Durden
    Oct 2003
    Massachusetts, USA
    CPC should be on. Other timings I am not sure about, but I reccomend asking SAE, Saaya, Last Viking, or Evil_Spork as they seem to know Infinity's pretty well.
    Try setting the timings to 3-2-2-11, you have plenty of voltage to work with so I wouldn't worry about it limiting your speeds...and the tighter timing is worth it, especially in an nforce 2 setup.
    Formerly XIP, now just P.
    c[_]
    Nov 2002
    Alberta, Canada
    ram timings:
    3(or 2.5)-2-2-2-11(x)-9-12 (x = adjustable depending on ram, some do better at 10)
    e-e-f-e (CPC, superbypass, etc)
    alpha timings:
    1-3-3-3-2-1-3 - The old standby
    1-3-3-3-3-3-4 - Most stable (SAE and LVK)
    2-3-3-3-3-3-4 - Setting on latest nF7 D25 bioses, may be worth a try.
    Drive strenght: 6
    Slew rate: 7
    Note: I have not tested "2-3-3-3-3-3-4" or adjusting the slew rate yet...
    Using 2-2-2-2-11-9-12-eefe-1-3-3-3-3-3-4-a-a-a-a-a I am stable at 250fsb on my BH-6 for 1000 (not a typo) passes of memtest test #5 so far...
    EDIT
    Click here for what is used on the D25 nF7 bios.. good starting point for adjusting drive strength and slew rate probably
    http://www.xtremesystems.org/forums/...280#post511280
    Heatware || 01.01.08; AND 111.2%
    Dead Z7S-WS? Click!. || XS Z7S-WS Thread || Current Dead Asus Z7S-WS count: 26+ ($15,000 in dead motherboards).
    All along the watchtower the watchmen watch the eternal return.
    Want to use my Anti-asus logo? Go ahead, but use this link please!: http://i853.photobucket.com/albums/a...sus/noasus.gif
    Bring back the game. http://reclaimyourgame.com/. EA are mean.
    Oct 2003
    Massachusetts, USA
    WOW, thanks a lot STEvil. I'll try some of that stuff and get back to this topic with results.
    EDIT: Well, here are first initial results....booted into windows and typing on it right now at:
    Settings :: 233 FSB, 2.8vdimm, 1.6vdd. (all stock)
    Timings :: 3.0-2-2-2-11-9-12-1-3-3-3-3-3-4-eefe-a-a-a-a-a
    Other :: 10x Multi; 2.33GHz @ 1.65vcore (laziness, for stability. I don't remember exact lowest stable vcore, somewhere around 1.500v)
    I need to test further for exact stability with memtest and such.
    nForce UDP 5.10
    Win XP Home SP2
    Oct 2003
    Massachusetts, USA
    Ok, im back and now stable enough for my likeing.
    - 233 FSB
    - 2.9vdimm
    Timings: CAS 3.0-2-2-2-11-9-12-1-3-3-3-3-3-4-eefe-a-a-a-a-a
    - 20 passes of memtest #5
    - 2 whole passes
    Error Free.
    Will try for more tommorow...
    EDIT: Am I one of the only ones useing/testing this stuff on the K7 platform?
    nForce UDP 5.10
    Win XP Home SP2
    c[_]
    Nov 2002
    Alberta, Canada
    no, but not a lot are that post about it it seems
    Oct 2003
    Massachusetts, USA
    Ok....
    - 245 FSB
    - 3.3 vdimm
    - 1.9 vdd
    - 10 passes of memtest #5
    - 5 whole passes
    Error Free.
    I tried 250 FSB but it only got through 3 passes of memtest #5 then errored (2 errors) at the end of pass 4. As soon as that happened I gave up on it. Im sure if I relaxed a few timings I could get it stable. But right now im happy with 245 at the current timings. Especially since this isnt BH-5. I've also got an 6800 Ultra coming in, in like 2 days so I want a pretty rock solid FSB for it's arrival.
    So those are my final results for now. I'd assume this would be a good reference topic for anyone pondering to buying this RAM on an NF2 system.
    nForce UDP 5.10
    Win XP Home SP2
