Results 1 to 7 of 7
Thread: Catalyst 3.2 and Radeon 9800xt
    Jun 2004
    Bari - Italy
    Hi all
    I've a problem with my graphic card. I want to lunch 3D Mark 2001se with Catalyst 3.2 but the vga isn't supported by that revision....
    I tried to modify the .inf files, pasting whe .inf files of Catalyst 4.7 (which supports radeon 9800xt). However I din't solve the problem...
    how to install thant driver on my vga?
    thank you very much
    Overclocker pagante
    Jul 2004
    Italy
    amore...
    Jun 2004
    Bari - Italy
    mi sembrava strano che qualcuno avesse risposto in questo thread :p
    Overclocker pagante
    Xtreme Gamer
    Jan 2004
    Europe
    u have to use the newer drivers ..
    Intel i7 930 @ 4.2Ghz 24/7
    Asus Rampage 3 Extreme
    Asus Radeon HD 6990
    Corsair Dominator GT 6GB
    Corsair AX1200, 600T
    Intel X25-M 160GB
    Dell U3011 30" Monitor
    Jun 2004
    Bari - Italy
    done but....i don't like it
    P.S. thank you for the pm....i read
    Overclocker pagante
    Xtreme Team DČOL
    Nov 2003
    Melbourne
    Use my modded 3.2's.
    I modded the 3.1's/3.2's/3.4's a while ago for use with 9800pro/XT...
    You can d/load them here:
    I noticed that the 3.1's are the best for 3DMark01SE... Then comes the 3.2's.
    There's instructions in the zip file I posted in that thread.
    Extract the 3.2 drivers, copy/paste/replace the original .ini/.inf files with my files & you're good to go.
    Once that's done, you can run the setup.exe for the 3.2's. With the 3.1's, you have to manually install them through the device manager.
    Good Luck.
    Minnyboy
    edit: My 25K score in my sig was with a 9800pro using my 3.1's... Using my 3.2's, I lost out a few hundred points.
    Cheers,
    Minh
    Mine:3770k @ 4.6Ghz @1.25v, Corsair H80, Asus SabreTooth Z77, 4 x 4GB Corsair Vengeance 1600C8, XFX 7870DD, Corsair HX850w, Sandisk 240GB Extreme SSD, Corsair Graphite 600T
    Kids: 2500k @ 4.6Ghz @1.368v, TRUE120, 2 x 4Gb Corsair Vengeance 1600C9, Gigabyte Z68X-UD4-B3, Gigabyte HD6870, Sandisk 240GB Extreme SSD, 850w Thermaltake 850w PSU, Antec P182 Case
    Kids2: i3 3225, 2 x 4Gb Kingston HyperX 1600C9, ASUS P8Z68-M PRO, Sapphire HD4870 1GB, 128GB Samsung 830 SSD
    Server: Core2Quad 9450, 2 x 2Gb Kingston HyperX 1066, 2 x 2Gb Corsair XMS1066, Gigabyte EP45-DS5, Corsair HX650w, OCZ 120GB Vertex 2E SSD, WD 1TB Black, 2TB Seagate 5900rpm, 2TB Seagate 7200rpm
    Jun 2004
    Bari - Italy
    Thank you very much
    I tried to change the .ini files but i din't reach any results
    Overclocker pagante
