Results 1 to 5 of 5
Thread: fir waterchiller insulation question?
    Xtreme Mentor
    Apr 2003
    Ankara Turkey
    Question fir waterchiller insulation question?
    yes this is the first time i will cool my cpy and gpu with chilled water so need advices on insulation
    water will be -20 and i am using zalman wb for cpu and homemade block for x800pro
    i am totally know nothing about this so need some advices on how to cover blocks will i need to use dielectric grease and how will i find sealing string or something that can make its job
    When i'm being paid i always do my job through.
    Mar 2004
    Murfreesboro,TN
    have u read thru the "sticky: Chiller/ ac unit" most of your questions will be answered in that thread
    Lian-Li PC-75B, Asus P5WGD2 WS Pro (BIOS 502), Intel Q6600 G0@ 3.5GHz 1.50V, G.SKILL BHZ, 2048-6400C4,4:3@5-5-5-15-5,EVGA GeForce 8800GTX 768MB, CC-644MHz / MC-1100MHz, HT OMEGA CLARO 7.1, Logitech z-5500 5.1, Enermax 660W SLI, Boot Drive - Raptor X WD1500AHFD 150GB, Two Storage & Backup HD's-WD 320GB SATAII inclosed in ICY Dock Hot swapable HD racks, NEC DVD +/-RW ND-3550A, Lite-on DVD ROM SHOD-16P, 52-in-1 cardreader, Deck Legend-Ice Keyboard, Back to my Logi MX500 @1000Hz
    -monitor#1 Dell 2407WFP rev. A04, res. 1920x1200
    -monitor#2 TV Vizio GV42L, connected with 30' RapidRun cable, Audio - 30' S/PDIF, Belden/Canare cable-> Marantz AV9000 5.1-> 5X 600w ADCOM monoblocks, Veledyne SPL-1200 Sub, SpecResearch keyboard.
    Custom Watercooled->CritiCool PowerPlant PCI Relay Card(modded)->Meanwell S150->Iwaki RD-30-> PA120.3 w/ shroud & Yate Loon D12SL-12 Fans, Nexus fan controller->Storm G5->MCW60
    Mar 2004
    So-Cal
    u mean liquid right also are you talking in c or f?
    Jul 2004
    Lake Stevens WA
    Do a search in this section of the forum on "Insulation" and you will find quite a bit of info.
    AMD 4200+ X2
    Asus A8N SLI Premium
    OCZ Dual Ch. DDR4400 EL GOLD 2GB
    WD Raptor 74gig (Boot)
    (2) Seagate Baracuda (Raid1)
    MSI 7800GTX
    Audigy 2 Platinum
    Enermax 535
    If the women don't find you handsome, they should at least find you handy!
    Xtreme Mentor
    Apr 2003
    Ankara Turkey
    yes i am talking about c
    and didnt search it because know nothing about this section tanks for the answers i will search just need a clue to start with ehhee
