Is it the same design as on the max3? I'm wondering if the ocz voltage booster will work with it or not.
http://service.futuremark.com/compare?2k1=6646300
http://service.futuremark.com/compare?pcm=1361699
http://service.futuremark.com/compare?2k3=921862
2.8E/Abit IC7-G/2x512 Corsair TwinX4000-Pro/Sapphire 9800XT 256/36 WD Raptor/Logitech Z-560/Viewsonic P95F+B
The ocz booster should work fine on most ddr motherboards.
it has been said by ocz themselfs that it doesn't work with the max3 due to the low vtt on the board. In other words it would still require the vtt mod. I pm'd andy from ocz and he said he wasn't sure about the max2. if it had the same vtt layout as the max3 it wouldn't work as well.
VDimm mods on IC7, and Max2 require vtt fix. I'm sure you'll want it if you are using the booster.
.........current project, make the 135i faster
so i take it i should NOT order the booster for my IC7? i would asume that the ic7 ic7-g and and the ic7-g max2,3 have the same vtt layout?
thx perc,
It will work, but you'll need to do a VTT mod on your own in order for it to be actually effective.
-Phenom2 x6 1055 @stock
-8gb ddr3
-Gigabyte UD3
-Geforce 7900Gt 755/1863 1.562v vgpu
-OCZ Powersupply 600w
hmmmmmm? so much for just poping that bad boy in and going for it! how hard is a vtt mod on that mb?
thx perc,
Cutting the trace is the "tricky" part...
Just follow either Hipro5's guide or Catch22APlay's guide.
I followed Catch22's guide & haven't looked back since.
Now happily playing with 1.7vtt ...
Put it this way, even I could cut the trace... The trick part for me is the soldering, I am very shaky....
Just a bummer that there are boards out there that b\neet to be modded anyways to use the OCZ Vdimm Booster...
Cheers,
Minnyboy
Cheers,
Minh
Mine:3770k @ 4.6Ghz @1.25v, Corsair H80, Asus SabreTooth Z77, 4 x 4GB Corsair Vengeance 1600C8, XFX 7870DD, Corsair HX850w, Sandisk 240GB Extreme SSD, Corsair Graphite 600T
Kids: 2500k @ 4.6Ghz @1.368v, TRUE120, 2 x 4Gb Corsair Vengeance 1600C9, Gigabyte Z68X-UD4-B3, Gigabyte HD6870, Sandisk 240GB Extreme SSD, 850w Thermaltake 850w PSU, Antec P182 Case
Kids2: i3 3225, 2 x 4Gb Kingston HyperX 1600C9, ASUS P8Z68-M PRO, Sapphire HD4870 1GB, 128GB Samsung 830 SSD
Server: Core2Quad 9450, 2 x 2Gb Kingston HyperX 1066, 2 x 2Gb Corsair XMS1066, Gigabyte EP45-DS5, Corsair HX650w, OCZ 120GB Vertex 2E SSD, WD 1TB Black, 2TB Seagate 5900rpm, 2TB Seagate 7200rpm
