m going to try out water cooling since i'm sick of the sound from my case fans. Right now i'm running an overclocked p4 cooled by an slk-947U w/92mm Tornado on a fan controler. I'd like to buy this case http://www.thermaltake.com/xaserCase...mi/bwa/bwa.htm, and use possible remove the lower cage to put the rad. My current case is cooled by 4 80mm case fans, the tornado, and the 2 power supply fans. What kinda setup would you recommend to give at least equivalent cooling, and bring the noise down? I'm planning to use blocks for the cpu, vga, and possibly chipset. Dunno if I should use 1 120mm on the rad or 2. Would cutting a hole for a 120mm on top hurt me very much for noise? The 2 120mm, and 1 92mm fans that are included with the case are rated at 21dba ea.
