+ Reply to Thread
Results 1 to 8 of 8
Thread: I think I kill 2 A64 in one night, need some help please!
    Registered User Trader88's Avatar
    Jun 2003
    Singapore
    0
    Unhappy I think I kill 2 A64 in one night, need some help please!
    Hi all,
    Let me try to keep this brief. I had been running my A64 3200+ 1MB L2 (its one of the early one) fine at 240 x 10 for more than 3 months. The detail is on my sig rig2. The setting was as follow: vcore 1.7v, vdimm 2.7v, vddq 1.6v, and ht default.
    Couple days ago when I boot up the system, it posted but with a message "scanning harddrive for bios image". I wasn't freak out at all coz it happen before with single bios chip Gigabyte board. I figured my bios is dead. So I got myself an 8KDA3J, thinking this will fix everything and it¡¦s a much better board. Every other parts remain the same.
    I fire up the system. Wow its even worst this time, no post at all. The system is power up alright with the on board debug display "FF". Cdrom and HD are on alright but search looping infinitely. I power off and reset cmos a few time but same result. I took out everything and reseat everything but same result.
    I figured, I think this is the famous A64 death I encountered. Although didn't understand how it happen coz I'm not running high vdimm. Anyway, I have another 3200+ right beside me on a KV8MAX3 just finished building for my girl friend. It¡¦s still a clawhammer with 1mb L2 and its running fine on the KV8MAX3.
    I want to try the new 8KDA3J so took out that 3200+ and slip it in and fire up.
    Damm, same result. At that point, I was thinking it¡¦s definitely somewhere is wrong in this system. Suspected the 9800XT or the PSU. Could these have killed the CPU?
    Anyway, slip back the fine 3200+ (I thought) back into the KV8MAX3..... ..... Now this is impossible......the KV8MAX3 system is now no post and siren non stop. Debug light shows "90". Not sure what that means and it¡¦s not on the manual.
    So that¡¦s it, I think I kill 2 A64 in 1 night. Is this possible. Is this the famous A64 death?
    Any thoughts guys help please.
    I will try to test the PSU, ram, and 9800 separately to see if I can isolate the problem. Even if there are bad parts in one of those, could they have contributed in killing the CPU?
    Sorry about the long story, and thanks for listening anyway.
    Gaming/General Usage | Win7 64
    Gigabyte GA-X58A-UD7
    I7 930 (3003A965) @ 4.2 (200x21; CL7-8-8-24/1600; VCore=1.35V)
    OCZ3F1600LV6GK 6Gb
    PowerColor 5970 @ 900/1110
    X25M 80G G1 X2 Raid0, Xonar D2X, Antec 1000W.
    Swiftech Apogee XT
    EK Waterblocks EK-FB KIT
    XSPC 5970 Full
    Swiftech MCP655
    Feser X-Changer QUAD 480
    EK-Multioption RES X2 - 150 Advanced
    Scythe GentleTyphoon 120, TJ07
    Fused tictac's Avatar
    Dec 2003
    Malaysia
    0
    i have ic7 max III bios ver 16 modded
    u want to give a go? pm me
    Jun 2003
    Singapore
    0
    Anyone has any thoughts? Are both of my A64 really dead???
    OCZ3F1600LV6GK 6Gb
    Swiftech Apogee XT
    XSPC 5970 Full
    Swiftech MCP655
    Jan 2003
    Leicester UK
    0
    IC7 is an Intel board, and how is he going to a get a new BIOS on a board that wont POST Without hotflashing or using a new BIOS Chip.
    Jun 2003
    Singapore
    0
    I have 2 quick question, hoping some of you could help out:
    1) Can I assume no post is CPU death? Because I suspected it might be the 9800 that die. But it can't be, the KV8 system also no post, so it must be the cpu.
    2) Does anyone know whats "90" mean on the KV8MAX3 debug?
    Many many thanks
    OCZ3F1600LV6GK 6Gb
    Swiftech Apogee XT
    XSPC 5970 Full
    Swiftech MCP655
    Xtreme Enthusiast Cranox's Avatar
    Oct 2003
    Terra
    0
    I got an MSI K8N Neo that wont post with my 9700pro ( any other card is fine )
    So i think its NOT ure cpu , try another vga card
    CPU : Intel Core 2 Extreme QX9650
    MB : Asus P5E X38 Rampage bios
    RAM : Team Xtreem 4x1GB DDR2 OPB handpicked
    VGA : Sapphire 4870
    Power : Antec Quattro 850w
    Storage : 1 x 60GB OCZ Vertex + 2 x 750gb WD 32Mb
    DVD : Samsungs DVDwriter Sata + Liteon DVD
    Sound : Creative XFI Xtrememusic
    Cooling : D-Tek Fusion + D-Tek Fusion GFX
    Monitor : Samsung 226BW
    Errorcode : An error occurred at address AC 20 DE AE FF BC ...... System halted.
    I am Xtreme Zeus's Avatar
    Feb 2003
    Netherlands
    7
    Fire up your system with only one HDD (with your OS) some mem and videocard and see what it does.
    If it's a no-go try a different videocard and different RAM, still no-go, measure the rails of your PSU with A MM.
    If all fails, take your new board+ both CPU's to the store you bought your new mobo and tell them the board killed both.
    GL
    Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
    Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
    Case: Murdermodded TJ-07
    sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
    Dec 2003
    Malaysia
    0
    ops.. sorry i misunderstood him...
+ Reply to Thread
