I am gonna buy this CPU and I would like 2 know about its overclock, i have a Zalman 7000AlCu cooler. And i would like 2 know what motherboard would u recommend me.
E5200
Asus P5Q-VM
A-DATA 2x2GB
Zotac 8800GT
500W Seasonic
Originally Posted by trakslacker
you would like to know about its overclock?
i dont know how many times ive said this, but its different for every chip. You could get a dud or a gem.
Asus G60VX : Intel T9600@3.299GHZ : Nvidia GTX260M @ STOCK/ .9v
personally, I wouldn't pick one of these for air cooling alone.
with the very high multiplier and tendency for P4s to max around 3.7 and 3.9 ghz at the very best on air, that means your gonna be running a very slow FSB at 1:1, like 220 or so.
personally for air alone, I'd be more inclined to look at the 2.8 or 3.0 and focus on running some ram at 1:1 at 250 or so.
it's not hard and would be a better overall OC with the P4 given that they tend to almost always hit somewhere between 3.7 and 3.9 max on air.
I heard that most does 4GHz on stock cooler.
but, for exemple. Karnivore already got a 2.8C that didnt go over 2.9, and Grace got one at 4.2GHz water...
U know i am from Czech Republic and normaly it costs about 500$ and i am gonna have it new 4 200$.
E5200
Asus P5Q-VM
A-DATA 2x2GB
Zotac 8800GT
500W Seasonic
Well, if you can get for only 200$, I wouldn't hesitate. Although that price seems xtremely low.
As for the board, I'd recommend the ASUS P4P800 - P4C800-E or the ABIT IC7-G, depending on which one you can get over there.
Rig #1
Gigabyte P67A-UD4 trying to figure out this POS board
2600k @ ?????
2x2Gb GSkill RipJaws-X 1333 (7-7-7-21)
ATI 5850
Coba Nitrox 750W
Watercooled with HK 3.0 CU, Watercool GPU-X³ 5870 Nickel, PA120.3, Laing Ultra with XSPC top
Rig #2
DFI UT P35-T2R (0317 bios)
E8200 @ 4000 (1.216V) / 4100 (1.248V) / 4200 (1.296V) / 4300 (1.344V)
2x2Gb Chaintech Apogee GT PC2-8500
Powercolor 4870
Corsair 520HX
Watercooled with HK 3.0 CU, EK-FC4870, Feser tripple, Laing Ultra pump
I can get both of the motherboards, but i would like 2 know which is better the Asus P4P800 SE or Abit IS7-E? Which has better bios configuration, i mean like more Vcore and mainly Vdimm core, cause 2.8V is not enough 4 me.
E5200
Asus P5Q-VM
A-DATA 2x2GB
Zotac 8800GT
500W Seasonic
Get the AI7 then, it can pump 3.2v into your RAMs without any vmods.
Ok.THX. I ve got one more question do u thin its better 2 buy A64 2800+ and oc it or take the NW3.4GHz and oc?
E5200
Asus P5Q-VM
A-DATA 2x2GB
Zotac 8800GT
500W Seasonic
the A64 2800+ probably wont beat the 3.4C.
And for the board, its AI7 all the way. It is better then any canterwood. And you can even enable PAT on it. It's a canterwood killer like Eva2000 would say. Its the best I got between a P4P800, MSI 865PE NEO2, and the AI7.
Good luck...
Buy the 3.4c resell it and use the profit to buy the 2800+.
Only the stupidest humans believe that the dogma of relative filth is a defense.
So know i dont know wich of this mobos 2 buy Abit IS7-E or Asus P4P800 SE.
E5200
Asus P5Q-VM
A-DATA 2x2GB
Zotac 8800GT
500W Seasonic
