+ Reply to Thread
Results 1 to 7 of 7
Thread: help : capacitor + mosfet mod on nf7-s rev 2.0
    Jun 2004
    Indonesia
    0
    can anyone help me to mod capacitor + mosfet on this mobo.thanks
    XS Intel News & D²OL enhanced enzoR's Avatar
    Nov 2003
    Netherlands
    0
    what do you mean by modding the mosfet? adding somemore. and by modding caps you mean changing them to better quality caps and more capacity or what? thats easy, just unsolder and resolder the new ones. keep an eye on polarity
    Jun 2004
    Indonesia
    0
    I'm willing to change the mofset because i have been read somewhere in the net, that the combination used in NF7-S makes the board instable at high bus, cmiiw.
    I'm googling but i don't find any link can help.
    Apr 2003
    Belgium
    0
    Keep us updated, I'm also stuck @ 245 fsb
    Venice 3500+ M @ 3ghz - Lanparty nf4 2 dimms dead - X800 - 512 Mb BH-5 - 1* WD360GD - 1*SP1213C - 1* Maxtor 6Y120L0
    Cpu: Prommy chilled
    Xtreme Hardware Killer bh2k's Avatar
    Jan 2004
    Behind you
    0
    Well from what I understand it would be as easy as finding another nf7 and getting the mosfets and caps from them and souldering them on in correct polarity.
    Level 80 UD Death Knight on Murmur (Beta)
    Jun 2004
    Indonesia
    0
    any diagram or picture??? please thanks.and the type of capacitor???thankx b4
    Apr 2003
    Belgium
    0
    Euhm,
    There are 2 connections it shouldn't be that difficult to connect them right I suppose?
    You only need to check that the maximum voltage is the same or higher, and for the capacity: higher=better
    Cpu: Prommy chilled
+ Reply to Thread
