+ Reply to Thread
Results 1 to 8 of 8
Thread: heat output calculation for a64
    Xtreme Addict sai's Avatar
    Jan 2004
    Frankfurt, Germany
    0
    Hi, anyone knows how to calculate the heat output of a 1mb cache A64 ?
    Admin Gautam's Avatar
    Dec 2003
    Hillsboro, OR
    0
    Roughly, multiply the clock speed by the voltage squared and multiply this by 0.0182 to get the heat in watts.
    c[_] STEvil's Avatar
    Nov 2002
    Alberta, Canada
    20
    161w @ 2600mhz 1.85v? hmm....
    Heatware || 01.01.08; AND 111.2%
    Dead Z7S-WS? Click!. || XS Z7S-WS Thread || Current Dead Asus Z7S-WS count: 26+ ($15,000 in dead motherboards).
    All along the watchtower the watchmen watch the eternal return.
    Want to use my Anti-asus logo? Go ahead, but use this link please!: http://i853.photobucket.com/albums/a...sus/noasus.gif
    Bring back the game. http://reclaimyourgame.com/. EA are mean.
    Dec 2003
    Hillsboro, OR
    0
    Works like this, voltage is a square factor, frequency a linear one. Got the .0182 by using the stock 3200+ data of 81.9W, 1.5v, 2000MHz. Take a look at .this for a detailed explanation. 163W sounds about spot on. Going above 1.8v isn't child's play with the A64, much unlike the AXP.
    Xtreme X.I.P.
    Nov 2002
    Shipai
    1
    eh? its not 160W!
    Xtreme Mentor blinky's Avatar
    Jan 2004
    Berkeley/Stanford, CA, USA
    0
    yah 2600mhz with 1.85v is like 120-130 watts or so
    can you see the light? is it shining too bright? can you see the light at the end of the tunnel, i know i do, i know its true.
    Dec 2003
    Hillsboro, OR
    0
    And what are you basing that on?
    Apr 2004
    Dallas, TX
    0
    I'm not sure if it is correct or not but Sisoft Sandra reports approximate CPU wattage at 106w and the formula gives me 107 and change. Seems like they are both using similar formulas whether they are correct or not.
    a64 3400+ @ 2700 (10x270) @ 1.6v
    DFI LP NF3 250gb
    2 x 512mb PQI Turbo 1:1 2.5-3-3-10-1t @ 2.8v
    Radeon x800 Pro
    Audigy 2 ZS
    2 x 36gb WD Raptors in Raid 0 via Highpoint Rocketraid 1520
    All air cooled in CM Stacker
+ Reply to Thread
