+ Reply to Thread
Results 1 to 10 of 10
Thread: Baker blocks or anything + latching on block
    Xtreme Enthusiast urbanfox's Avatar
    Mar 2004
    Fullerton, California
    0
    I need to get a block this week, and preferably i dont want to do that all brazing or whatever i just want to buy something that i can hook up immediaetly to a custom unit. and what baout this? http://www.frozencpu.com/cgi-bin/fr.../ex-vap-07.html is that a block? like could i just buy that and hook it up to a custom unit?
    So how do you (u the person owning one, not "u" as in the forum or "u" as in me) latch on the cpu block? ive heard everyone does it different, but is there any safe clean method that doesn't involve duct tape or something?
    Xtreme Guru craig588's Avatar
    May 2004
    the cold place Temp: 5C
    0
    My method is using a hole saw to cut a hole thats aproximately the same size as the insulated suction line+ cap tube in a peice of lexan, Then I use a jigsaw to make a small line in it so I can slide it on. That takes care of attaching it to the evap head.
    Then I use a drill press and put 2-4 holes in it that match up with the socket holes on the particular mobo or card.
    I send bolts with little rubber washers and springs through the card/mobo and have the nuts on the outside of the lexan sheet on the evap head.
    I'm sure that the guys that use better phase change systems will know of better ways though.
    For those of you about to post:
    Xtreme Owner FUGGER's Avatar
    Jun 2002
    Las Vegas
    10
    That is not a block, it is the housing to fit a vapo unit onto sockets 478/754/940
    ASUS Maximus Gene V
    ASUS GTX 680
    Intel 3770K Overclocked
    Intel RTS2011LC Cooler
    Corsair Dominator GTX 2
    Corsair Force GT RAID 0
    Corsair AX750
    Intel I7 3960X
    Asus Rampage IV Extreme
    Asus 580 Matrix SLI
    Corsair Dominator GTX 8GB
    Antec 1200W PSU
    Dimas Benchtable
    May 2004
    0
    I couldnt even access the link, so I went off on a guess that I hoped awnsered part of his question.
    Mar 2004
    0
    ok, what's a goo block that already comes assembled?
    May 2004
    0
    thats quite a long sig you have there.
    Mar 2004
    0
    but why does it only have one outlet? shouldnt there be 2?
    Jun 2002
    Las Vegas
    10
    The cap tube goes inside the suction line and you should secure the cap tube inside because it is a nightmare if the cap tube comes loose after you charge the system. One drawback to pre assembled blocks.
    ASUS Maximus Gene V
    ASUS GTX 680
    Corsair AX750
    Intel I7 3960X
    Asus 580 Matrix SLI
    Antec 1200W PSU
    Dimas Benchtable
    Feb 2004
    Tucson, Az, USA
    0
    OT: That site sells a universal Socket A to Socket 754/939 converter. I didn't know such things existed.
    http://www.frozencpu.com/cgi-bin/fro...ex-blc-77.html
    Jun 2003
    Jacksonville, NC
    0
    the baker block at xtwerkz.com
    Asus G60VX : Intel T9600@3.299GHZ : Nvidia GTX260M @ STOCK/ .9v
+ Reply to Thread
