+ Reply to Thread
Results 1 to 6 of 6
Thread: Hotflash?
    Jan 2004
    0
    Question Hotflash?
    OK, so I screwed up the BIOS chip on my NF7 V2.0, so I need to do a hotflash.
    I've gotten my hands on a working BIOS chip, but I want to be sure, what to do
    1. Put the "healthy" BIOS chip in the NF7 and boot up. Shutdown right after.
    2. Then swap the "healthy" BIOS chip with the "unhealthy" chip, and the rig should boot up normally.
    3. Then flash the BIOS and I should be good to go.
    Is this right procedure?
    Thanks....
    Xtreme Guru craig588's Avatar
    May 2004
    the cold place Temp: 5C
    0
    Nope, you need to acctually have the computer running and remove the chip and put the new one in. You cant shut it down at all.
    For those of you about to post:
    Xtreme Addict LilGator's Avatar
    Jan 2004
    0
    A few modifications ...
    2. Then boot AWDFLASH and get ready to flash
    2. Then swap the "healthy" BIOS chip with the "unhealthy" chip.
    3. Then flash the BIOS, reboot, and it should be good to go.
    Xtreme Mentor blinky's Avatar
    Jan 2004
    Berkeley/Stanford, CA, USA
    0
    umm, i dunno how it works with awdflash, but i just use abit's flashmenu,
    so u
    1 boot up with good bios
    2 take it out
    3 put bad one it
    4 flash with flashmenu
    5 reboot and ur done
    can you see the light? is it shining too bright? can you see the light at the end of the tunnel, i know i do, i know its true.
    Jan 2004
    0
    Yup, either way would work ...
    Jan 2004
    0
    Thanks guys.
    There's always help to get here!
+ Reply to Thread
